Bicycle Wall Mount From Pallet Wood
3,128
38
4
Published
Introduction: Bicycle Wall Mount From Pallet Wood
About: I´m a Youtube and Twich streamer on Creative #woodworking, I do ugly fulgy stuff from reclaimed wood and other materials.So keep recycling, lets make it fun !!
So my Bicycle was always in the way and so I fix it.
Was a Project that i did you the fly no planing aside, well plans who need thems :P
Let you imagination go and do it !!!!!
For more wierd projects check my youtube channel
Step 1: What You Need
* Pallet wood
*screws
*wood glue
*washers
*threaded rod
*lock nuts
Step 2: Cut Wood and Glue the Boards
Cut the Wood to a size that you can glue together
Step 3: Glue Them Together
You can use this tip tho glue them
Step 4: The Side to Hold the Rod
Cut a shape to hold the rod and with enough space to the iron move
Step 5: Make 2 Equal Holders
I used a router to make 2 pieces alike
Step 6: Scrap Iron
Make sure you use something that strong enough to hold the bike. I used a scrap Ironbar
Step 7: Strength for the ROD RWaaarrrr
cut some wood bolcks to use as spaces and add strengh to the threaded rod
Step 8:
Glue , pre dril and add some screws to the sides
Step 9: Drill the Holes
Put some holes as you like to attach it to the walla
Step 10: Lock Nuts
Put the lock nuts on the threaded rod
Step 11: Back Tire Wood Support
Use a scrap piece where you can you the back tire and thats it
Step 12: Attach to the Wall and DONE
Last part is put it where you want it :D and put the bike in and there you home made bike wall mount
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    4 Discussions
    that's awesome. now to make this a double hook or even a quad for our bikes... jejeje
    thanks for sharing.
    Thats a good idea but the threaded rod should be thicker for sure
