DIY Bicycle Wheel Pots and Pans Rack
 by womynking
Step 2: Prep the Wheel
If your wheel still has an axle and tire, the first step will be to remove them. If your wheel is already bare, skip to step 3.
To remove the axle, loosen the nuts on each side with using the adjustable crescent wrench. Discard all ball bearings and other parts which may fall out.
Deflate tire and slip off the wheel. Clean and dry the wheel, then set it aside.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
