3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bicycle cargo trailer--200 lb capacity, $30 for parts
This bicycle trailer is made from 1/2" EMT conduit that is bent and brazed into a frame. It uses scavenged bicycle wheels, has a plywood cargo bed, and can be modified for any use easily. The frame alone weighs 15lbs, and with a hitch, plywood, and wheels it weighs 25lbs or so. It carries 200 lbs safely, and it can haul up to 450 lbs carefully.
Step 1Obtain parts and tools
Tool list
1/2" conduit bender
hack saw
tape measure
marker
punch (or nail)
hammer
vice
1/8" bit and 3/8"
drill
half round file
oxy-acetylene torch or arc welder
plentiful brass brazing rod
brazing flux. goggles, and gloves
bricks for holding frame
framing square / "L" layout tool
Finding and Buying Parts
You can find a lot of the parts, particularly if you're near a metal dumpster or a building renovation that might be ripping out conduit. Metal shops often have scraps of flat stock that you might be able to take.
Wheels: Go with what you can find. Feel lucky if you have the option of mountain bike wheels over road bike wheels. The dimensions given here are for carts with 26", 27", or 700c wheels. If you use 24" wheels, you can reduce the cart depth by 1", and if you use 20" wheels reduce the dimensions by 3" (spine and ribs dimensions). 700c and 27" wheels work, but ther're less strong, particularly laterally, which is important when you're hauling a load around corners.
Find wheels at bike shops or in the dumpsters out back. I've had good luck asking bike shops for old wheels, and in college metal recycling dumpsters. Make sure you get 2 of the same diameter, with the diameters within 1/2" or so with the tires on. You can get tubes with small punctures behind bike shops.
Another wheel possibility: It's easiest to use 2 front wheels because they will have the same hub spacing. However, you can use a front wheel and a rear wheel if you make one of the wheel wells longer and increase the hub spacing for the rear wheel to 4 3/4", instead of 4". Or measure your wheels exactly. Hardware stores carry the EMT conduit and hardware.
You will save some money if you can find scrap 3/16" by 1" bar, plywood and 3/8" ID tubing. Try metal dumpsters, scrap bins at machine shops and mechanics' garages, etc.
In the store, hardware parts are generally less expensive in the bulk bins than in pre-packaged boxes. I can't find rod end ball joints anywhere accept mail order (I've used McMaster-Carr). The shaft should be 1 1/4" or more, and have threads that are 3/8"-24 or 3/8"-16. (The 24 and 16 refer to threads per inch.) Get a nut to match the threads. The hole through the ball should be 3/8" wide. You can order it from mcmaster.com. It is part 6072K64 for the oil-impregnated bronze race with a chrome plated steel ball and right hand threads. It costs $5.92 without shipping. I think shipping is $3 or $4. You might consider getting a welding respirator ($12) from McMaster-Carr at the same time.
For plywood, ask at a lumber yard if they have scrap wood. Building renovations and construction also generate waste plywood that will work fine.
Using the tools
To use a conduit bender, line up your bend mark with the arrow on the bender. Step on the foot plate, while pushing down and pulling sideways on the handle of the bender. Bend until the bubble level reads level with no force on the handle.
Working with metal in this project is easy, but takes some practice. To cut with a hacksaw, make sure the piece is clamped well and the cut is close to the clamp. Use the full length of the blade, pushing down hard enough to cut but not hard enough to bind the blade. Use steady, even strokes pushing forward. Don't press down hard on the return stroke. Hold both the back and front of the saw.
When using files, the cutting happens on the forward stroke. Pulling back with downward pressure on the file will only dull the file.
To cut with a tube cutter, align the mark with the cutting wheel and tighten the screw just enough to score the metal all the way around the tube. Tighten a little more and continue turning the tool, ensuring that the cut is in the original groove. Continue around the tube. This tool is useful for the conduit, but a hacksaw is more reliable.
To braze with an oxy-acetylene torch, it's a good idea to get a lesson from someone who knows how. Always set the regulator carefully and keep the tanks well secured so they could not fall. Use gloves, #5 shade eye protection, and work on non-combustible surfaces. Keep fire-extinguishing paraphernalia present. Work with good ventilation, especially with galvanized conduit.
To drill into metal, make a starting dent with a punch or nail, and drill a small hole at high speed with a sharp metal bit. To enlarge it, use a lower speed and watch out for the bit catching as it breaks through the material. Always drill into material secured in a vice or by clamps.
General safety: Wear gloves when things are hot, don't wear gloves with spinning tools. Wear safety glasses when there are chips flying (drilling, cutting). Wear long non-synthetic, non-flammable clothes when working with the torch. Wear closed-toe shoes or boots. Don't breathe fumes from cutting, heating, or painting. Have fun and take care of yourself so you can ride your bike and pull your bike cart and tell your friends how great it is to not use a car.
77 comments
1-40 of 77next »
Nov 7, 2011. 9:20 AMst_indigo says:
Hey Aaron, great instructible, and good job with the documentation of the build.
I ordered a couple 14" wheels from Surplus Center with the intention of making a bike trailer and wanted to pass along the link. They have over 2000 in stock, and they are cheap, durable, and non-pnuematic.
https://www.surpluscenter.com/item.asp?item=1-2770&catname=wheels
The only issue is that they are hub-less, and would need a well-greased axle (9/16", I believe), though long bolts would probably work just fine. The design of the cart also would need to be modified for the smaller wheels.
Oct 2, 2011. 4:04 AMolmon says:
The neatest hitch idea I have seen yet is at this one - - http://www.instructables.com/id/Welded-bike-trailer/
Aug 13, 2010. 3:06 AMstrollersstore says:
These Trailers are amazing to look and very useful
Aug 4, 2010. 2:37 PMco2wms7whcc says:
Really, MIG welding is fairly easy to learn. Especially if you braze, because you will already have practice watching the bead.
Jan 1, 2009. 5:57 PMCrashbox says:
Here's a cart that started as a trash find. It was an InStep bike trailer I found in a neighbors trash. I welded in a couple of frame supports, changed the hitch, welded up the 3/4 emt tubing, added lights, works great. Crashbox. dog.house9@verizon.net
Jun 24, 2010. 7:44 PMEric B. says:
Crashbox, I am interested to know how you built the axle assembly for this trailer. It looks awesome! I have been creating plans for a trailer like the Y-frame that Carry Freedom builds but I can't seem to figure out how best to mount the wheels without building a 'wheel well'. I like the clean looks of yours.
Jul 11, 2010. 5:29 PMCrashbox says:
Eric, Attached are pictures of the wheel mounts.
Jun 25, 2010. 12:06 AMbikerusl says:
I would caution people about brazing the coated or galvinized metal. That stuff is extremely toxic, you don't want to breath any chrome! Other than that this is the most professional seeming DIY trailer I've seen. Good job. I build trailers with CrMo bicyclefamily.ca
Apr 14, 2010. 11:41 AMhackin5hit says:
Thanks for some inspiration!!! Because of this Instructable, I made my own trailer, viewable at
http://undefined-macrolife.blogspot.com/
Thanks again, I will be making one from your design this week. I weld them, and am very much a beginner welder so the welds are ugly (getting better fast though). Anyone in the Olympia, WA area wanting one of these contact me through here or the link, I'll help you build one, it is fun.
Apr 7, 2010. 7:57 PMfoothillfrontier says:
So glad that you have this posted on instructables. I was going to make this cart a while ago and lost track of the instructions. It was the first thing that popped up when I googled EMT Bike Trailer. Thanks!
Sep 5, 2009. 9:41 AMclockworkdoorbell says:
What a great project! I've just cobbled together my first trailer from bits and pieces, it pales in comparison to your professionalism.
Here are some photos. It was the hitch that flummoxed me the most.
http://picasaweb.google.co.uk/clockworkdoorbell/Trailer#
Aug 21, 2009. 11:54 AMcavegit says:
How do I convert my salvaged rims that I have to bolt on one-side, instead of having to bolt them on both sides of the rim? Almost completed my 2 carts with a 225lb. each weight limit. I used a frame from 2 fold out lawn chairs that I had gotten from CVS for 90% marked down price :)
Aug 21, 2009. 12:37 PMcavegit says:
I dont wanna spend $35 per rim for these and i need 4 total :( http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200331764_200331764
Aug 10, 2008. 9:11 PMgoodgnus says:
Almost finished, just need a plywood bed and add some nylon washers to the hitch to stop a little rattle.
Apr 17, 2009. 12:17 AMtobbylj says:
i think there is buffer between, just steel pin contact is very hard, not comfortable with bike rider
Mar 29, 2009. 12:10 PMSureShot says:
This is great, thanks for an awesome instructable!!!
Mar 9, 2009. 10:24 PMdm_metalsmith says:
this is fantastic! thank you! i've been playing around with trailers for some time. i've got a shabby wooden one right now that squeaks like an old rocking chair. i haven't really tried to max it out. . . it's still needs some finishing touches. this is a great instructable! i love the pictures too! - doug from somerville
Jan 2, 2009. 5:33 PMjeremysp1993 says:
you could mount that ball joint horizontally from the plate going to the left...and inside the ball joint, you could attach another ball joing going in the same direction that you have yours already in the picture...this would allow for movement up and down and left to right...that is if you have your ball joint freely moving within the tube that is attached to the bike
Nov 2, 2008. 11:57 AMThelonelysandwitch says:
my cousin made one of these but with smaller wider wheels. it worked great.
Aug 5, 2008. 2:47 PMgoodgnus says:
You can get plans in PDF format from the original designer at http://bikecart.pedalpeople.com
Plans are very comprehensive. I built a slightly modified version of this last weekend, almost complete, very sturdy, looking forward to using it, see attached pic.
Uses 20" bmx wheels instead and moved back to aid stability, details in the PDF version.
May 18, 2007. 3:25 PMfarbs says:
Hi! Im 13, and I desperately want to build a trailer. The problem is, I dont own a welding gun (Mainly because im 13) but my moms boyfriend is a carpenter, and I could probably convince him he could use one. If im lucky,he might get one by christmas. Then I could get the parts and make it by Febuary. way too much work. I dont think he would let me use it anyway and its not the same watching someone else build it. So even before I saw this, I decided that I would build a cheap, no-weld trailer. Any suggestions or tips?
Jun 26, 2008. 5:47 AMzach911 says:
if you were to weld make your sure you were a helmet. the bright light could burn your retina in 15 nanoseconds. thus causing you to lose ability to see.
Jul 18, 2008. 9:37 AMbumpus says:
"Wear" not "were" "god ppl learn English"
Jul 18, 2008. 10:22 AMzach911 says:
Dude its people not ppl
Jun 5, 2008. 9:35 PMportland454 says:
Aluminum is great. I had a friend in high school who's grandpa built him a trailer using the the 'L' shaped aluminum rod(angle iron). We used it for our surf boards for years. You can use screws to bolt it together. Be sure to use lock washers/bolts. You might also consider looking at reclaiming used material, such as rods from an old patio umbrella, lounge chair, etc. Good Luck and don't stop until you've got it!
May 13, 2008. 9:18 AMGrey_Wolfe says:
You could probably build this same trailer using brackets and pipe fittings instead of welds. Though it may not be quite as strong, it should still be rather structurally sound.
Feb 24, 2008. 12:34 PMKevvixx says:
If I were to use bamboo, where could I get it?
Feb 24, 2008. 12:32 PMKevvixx says:
what is a good cheap material that I could use since you said that PVC was not a good recommendation?
Mar 19, 2008. 2:31 AMcamb00 says:
copper pipe no welding just soldering but its very expensive now but would be easy to use
May 13, 2008. 9:23 AMGrey_Wolfe says:
This is a good suggestion for ease of costruction, though it would have to be for farely light loads, copper is rather soft. PVC is very sensitive to sunlight, it will scorch and become even more brittle than it already is. Aaron's right, it's a bad choice. Threaded piping/tubing is a good idea. Preferrably aluminum, though steal would work, it'd be very heavy.
Feb 24, 2010. 2:07 AMLokisgodhi says:
I'd say fiberglass tubing would be a good substitute for bamboo. It comes in round and square.
Jun 26, 2008. 9:36 AMshyrell says:
What an amazing idea. I've been thinking of all things I could use these carts for: haul my 7 cats around town (kidding), hook one to the back of my riding mower, modify a wheelbarrow... Could you design something like a wheelbarrow? It would have to be easy to push and pull up to (but not including) 100 pounds, easy to lift the handle and set it down, and of course built on 2 wheels. I have a few small hills in my yard and I am not very strong. Or could you design a cart for the back of my riding mower that does not need a ball and hitch devise to attach and remove? What a great instructable! Thanks so much for sharing this idea. Shyrell
Jul 26, 2007. 3:41 PMdancmarsh says:
does anyone know the best place to get emt conduit in the uk? It seems that everyone uses PVC here. Is it known as something else? Can't seem to get it easily at all. Love the design, need to learn to weld anyway, seems like the perfect way to learn!
May 2, 2008. 3:30 PMkillerjackalope says:
B&Q and homebase do this stuff, getting to it is the fun bit, I've spent an hour explaining to the peons to take me directly to the metal threaded plumbing pipes for example, at one point we ended up in the only easy part of the stores to find... Lighting... However they do it and cheap aswell, B&Q are cheaper as memory serves...
May 2, 2008. 6:25 AMkington99 says:
Metal supermarket is a UK chain that sell material of this nature in any quantity rewuired, cut to size. It will be plain steel tubing rather than conduit, but as far as I can see there's no difference. I presume he only uses conduit because oif its ease of availability. Steel conduit is no longer used in the majority of UK wiring, doesn't surprise me you can't buy it anywhere.
May 2, 2008. 5:43 AMaltomic says:
I found an old beat up shopping trolley. removed the cage. welded to front bike forks to the sides (took the wheels off first). welded a bar bent midway at 65degrees which attached to my bike rack with a hand made universal joint thing. remember : it is a hell of a lot easier to pull than carry.
Nov 6, 2006. 5:32 AMskeegan says:
Hi: I have a couple of pieces of copper piping - about 2.5 m long and 25mm diameter. Would they be suitable for this project? I will bolt not braze..
Dec 28, 2007. 6:35 AMcamp6ell says:
you can probably sell the copper for more scrap value than the cost of (stronger) new steel conduit...
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:aaron
I'm interested in dialogue about the process of responsible facilitating inter-cultural and international technology-based development, as a white western trained designer, working on communities in w...
more »
