Step 2Bind and Tie
Bind each piece to the nail with thread or tape. If you're using thread a figure-8 twist will hold the pieces tight to nail while allowing other pieces to get tight too. This is tricky, you want everything bound up tightly, proceed with caginess :)
If you're using thread then repeatedly and tightly wind the thread around the assembly. Use super glue to cement threads together. Wrap the assembly in tape. This will serve as your handle. Leave the top exposed, you will strike the exposed steel ends with a hammer to drive the headset cup out.
Add Comment
