loading
Step 3: Horizontal Tube (bicycle Rack)
Bike on stand is clamped by skewer to 100mm axle and also from the other side supported under bottom bracket.
I've measured all 4 bikes I have (frame sizes vary from small to medium: Mongoose M trekking, specialized S road, Giant M road, Giant S MTB ) and is more less similar distance ~60-65cm between bottom bracket and fork axle. Fortunately the weight stands had adjustable height so I've made the horizontal pipe adjustable for future flexibility.
details of the axle and skewer you can see on the picture and sketch.
Because the smaller pipe was slightly wobbly I attached pieces of plastic at the end.
On the other side I screwed two pieces of thick plastic to support under bottom bracket and make a gap to prevent cables touching the rack (see photo)
<p>Good idea with this bike stand. Me and my beloved other half are in our 70s and love cycling, and I have been a cycle maintenance nut since I was seven when I used to come home from the local dump (Sheepcote Valley in Brighton in the 50s) with all sorts of bike stuff, it's a wonder my mum didn't go around the bend. Anyway we have had all kinds of bike in our time from racers to mountain bikes and so on. In 2002 we were having difficulty getting our legs over (just the bikes) so we bought two Peugeot Toulouse 105 step thrus. They are shire horses of bikes and weigh a ton, (45kilos) the both of them. They are lovely sturdy bikes, and although they are heavy when you are on them and riding they just roll along like a racer. We bought a Maxx Raxx bike rack for the back of the car which also doubles as my bike repair stand. ( I got there in the end). It is similar to this stand and is just right for my work. It is also 40mm square steel. I can do every job needed on the bikes (sitting down). I have made false crossbars for the bikes from 50mm ali' with 3mm thick wall. Just love messing with bikes.</p>
You know I was originally turned off from this idea AT FIRST! Then I took the time and browse through as I love bike repair and love to make my own stuff (tools, stands, etc). THEN I saw the finished part of this and thought THIS IS FREAKING BRILLIANT!!! Love the fact it is not like the ones made out of beer cans and pop bottles (sarcasm). In fact put it to the test it would hold a small engine block. Thats the kinds of things I like to make, overkill lol. Gonna see if I still have a patch to send if not CONGRATS!!!!
Thanks. I found it actually better for working with drive train and bottom bracket than a standard &quot;clamp&quot; style stand. Brakes you can adjust on standing bike, and saddle is even better adjusting in normal bike position . The other thing is, that the clamp is probably the most complicated part of the stand if you want to make it by yourself (I would say 70% of the time).<br>Keep'em rolling.
About This Instructable
14,677views
18favorites
More by thewhite:Sealed cables on cheap (winterize your bicycle) Holowtech 2 bearing change (#2) Garmin bicycle GPS (705/805) mount (to stem faceplate)
Add instructable to:
