3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bicycle seatpost toolkit
This barely warrants pictures, but I'll upload them anyway.
I just put some tools (3 tire levers) and spare parts (valve caps, a schrader valve core, zip ties...) in my long 26.0 diameter bicycle seatpost. I then put a spare handlebar cap into the end to keep the stuff from falling into my frame.
It is a very simple idea, but I think it has potential, maybe hiding other useful things in the tubes of a bicycle.
Step 1Laying out the stuff
laying out the stuff
One needs to figure out an arangement of the parts and tools that will fit in the seatpost. The levers only fit side by side with their hooks facing opposite directions.
7 comments
Jan 5, 2008. 9:17 AMMyself says:
Does the cap work loose after going over a lot of bumps? That's the only downside I can see to this elegantly simple, ingenious, trick. I've seen expanding "pipe stopper" plugs that use a screw to compress a rubber donut, which expands outwards and seals quite firmly against the walls of the pipe. With an eyebolt or wingnut on the screw, they're installable and removable by hand, and would definitely hold tighter than a press-in plug.
Sep 4, 2008. 9:41 AMwiretapstudios says:
A better solution (to add to it) is a one gallon ziplock bag. Put all that in lined up at the bottom, roll it up, and the extra bag will be easy to grab, and keep it from rattling. Thanks for the tip though, I will definitely be using this one.
Feb 29, 2008. 10:22 AMFuzz2050 says:
Doesn't that rattle around something awful?
Dec 25, 2007. 10:31 AMnsoles says:
I used to do this during my mt. biking prime of the early 90's. A rubber stopper was my plug of choice, often with a useful allen wrench stuck on the inside. I found use of a $5 bill wrapped around the wrench when I was in need of food far from home.
Dec 21, 2007. 2:48 PMGorillazMiko says:
very good idea!
Dec 21, 2007. 1:03 PMmcvarij says:
Good idea, but if you don't have a quick release seatclamp, you'll need a tool to take the seatpost out. Kinda defeats the purpose if you have to carry a wrench around.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:frogmeetcog
I enjoy making things of all sorts, with an emphasis on bicycles, tiny/useful/just plain nifty devices, cartoonish arch-villany, and not destroying the planet we live on. If those last two thing sound...
more »
