3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bicycle torque wrench from a fisherman's scale
Bicycle torque wrench from a fisherman\
Occasionally when working on your bicycle it is advisable to use a torque wrench suitable for measuring inch pounds. The infrequent user does not particularly want to pay out twenty to forty dollars for a tool that seldom gets used. You can do your torquing jobs with an investment of only six dollars for a dial indicator fisherman's scale. You probably have the other things you will need.
Step 1Calibrating the scale
Torque is force over distance. Pulling the end of a ten inch bar with a force of four and one-half pounds will put a torque of 45 inch pounds on a hex key.
Get a dial indicator fisherman's scale at a sporting goods department. These run about six dollars and read up to 50 pounds in one-half pound increments.
Your scale may be accurate at some weights, but may vary at others. Calibrating the scale is easy. My carbon fiber seat post has a recommended torque of 45 inch pounds. I want to place a weight of 4.5 pounds at the end of a ten inch bar.
Water weighs 8.33 pounds per gallon. There are 8 pints to a gallon and 2 cups to a pint. The weight of a plastic milk jug is negligible. Use a kitchen measuring cup to pour four pints and one cup of water into the milk jug.
10 comments
Sep 27, 2010. 4:36 PMshrpshtr325 says:
just a comment on this, the torque is equal to the force (applied at a 90degree angle to the handle of the wrench) times the length of the handle, if you pull on the scale at an angle other than 90 (approximately, im sure a little bit off wont hurt too much) you will be exerting a different than intended torque on the part (lower, which means that it could come loose on you while riding)
Oct 21, 2009. 2:08 AMsharlston says:
great ible is that a specialized mountain bike?
Oct 22, 2009. 12:06 AMsharlston says:
nice i ave a falt mystic pro 2009 bmx
Mar 16, 2009. 12:04 AMkearney says:
what if you were to take say a foot long piece of pipe and weld a ring to the end for the scale? when you wanted to use it all you'd have to do is slide the pipe over the shaft of the wrench and attach the scale. then you wouldn't need a long handled ratchet, and you could better judge the distance of the shaft.
Aug 11, 2008. 6:37 PMgritz says:
If you've ever snapped off a bolt or stripped the threads of a nut because you didn't know your own strength you'll appreciate this advice and torque wrench setup. A little ingenuity goes a long ways in being more precise in making in-lbs adjustments .... plus, need I say, saving some bucks in not having to purchase a store-bought' tool! Good idea ..........
Aug 11, 2008. 8:28 AMreddeth says:
Wow, crude but extremely ingenious. Very nice!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
