3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bicycle trailer made from a Roof-rack and fire guard
 i managed to get together various parts to create a multi-use bicycle trailer.
the main frame is an old car aluminium roof-rack, fitting the wheels was hard but i utilised the tube clamps that came with it (sorry i don't know the correct name of them).
the main axle was too weak so i changed it to an old steel tent pole,
and the cross piece at the front is also a section of steel tent pole.
the metal cage is a fire guard, it's held together with hose clips these are fully adjustable and reuseable.
Step 1The basic frame
The basic frame
Here the Roofrack frame is clearly visible as a light grey surrounding the whole trailer. good thing is the roofrack already has loads of easily adjustable bolts so no welding needed.
the central "T" shape is steel i tried the trailer without the "T" but the wheels were dangerously loose whaen any load was applied to the frame. not having the tools to drill through steel i had to improvise with hoseclips which are surprisingly easy to use and very strong.
the metal cage (brown colour) used to be a fire guard, i had to bend the pieces with a Vice and hammer but again quite easy to do.
from this angle its quite easy to note that both wheels are leaning out, i can't seem to do anything about this but it the wheels straighten when weight is put on the trailer.
the hitch, AAAAGH! horrible! its the handle from the top of a scooter forced onto one of the steel poles i've had massive problems securing it it basicaly hooks onto a "U" section i attatched to the bike it worked ok but rattled alot and actually fell off twice whilst in use(which i've since changed to a much safer system!)
2 comments
Jul 10, 2008. 5:50 AMrimar2000 says:
Good job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:RAPPLEBY2000
