Step 14Drill your 1/2" Holes
If you use option (1) or (2) read the safety instructions in the manual that came with your tools. You are liable for injury or damage caused by your failure to comply with safety and operating guidelines of your tool.
Option(1) is the best in my opinion. For those of you whose modus operandi is to constantly try to justify buying more tools for your garage (like me) now is the opportunity to get a small drill press for $85 at your local hardware store. A drill press is nice because it drills straight through the Superstrut. With a hand drill this is a little harder. Note that the holes need to be straight through the Superstrut or your pieces will look crooked when they are mounted to the stand.
For this step you have to drill completely through both sides of the Superstrut. If you choose your drill press, set it to low speed. Don't press too hard. It should take about 1 minute per hole. NOTE: The tills (shavings from the hole) are HOT! You must wear safety glasses when doing this. You could get small piece of metal in your eye like I did on another project. It caused a rust ring in my eye and I had to do to the eye doctor to get it out.
Add Comment
![Voltage Regulated [5v] Bicycle Dynamo Light & USB Charger](http://img.instructables.com/files/deriv/FKR/TCHO/GSEEJZIP/FKRTCHOGSEEJZIP.SQUARE.jpg)
