Big 7-segment Digital Clock
131,246
64
78
Posted
Introduction: Big 7-segment Digital Clock
Using only 2 capacitors, 3 resistors, 4 BIG seven-segment Display, 1 xtal, 2 switches ,and 1 Microcontroller PIC, you can build this Digital Led Clock main circuit.
you can use common anode or common cathode display, just select the display type. Here is the pinout information:(I have attach the all diagrams of parts and 7 segments)
I'm used 4x 6" big 7 segment display's.
​Ok now everyone who need this kit buy over here:
​http://innovatemodz.com/shop/uncategorized/digital-clock-diy-kit/
Step 1: Simple Paper Copy Schematic
here is the schematic and part list for the project.
IC - PIC16F628 / PIC16F84A
Step 2: Collect Your Parts:
PIC16F84A
3x 10K Resistors
2x  tack switches (micro switches)
4MHz Cristal (XTAL)
2x  22PF
If you are planing to protect your IC you should connect the IC through 5V regulator (1x 7805)
Vero baord(I used dot matrix board)
and other 7 Segment driver circuit parts displayed with attach image.
Step 3: Solder Your All Parts
Solder your all parts on to your vero board matching with this Circuit diagram.
Please do not solder your PIC16F84 on your board.Fix that through 18 pin IC base or Zif socket.
Step 4: Make Your Enclosure
Make a enclosure box  for clock.(makes with plastic acrylic sheet + glue)
and completed circuit board and 7segment board fix on your back plastic acrylic sheet.
and fix the Hour and Mins adjusting button to your enclosure right side panel.
Step 5: Programe Your PIC16F84
I have attach the HEX (16F84 clock) file for this clock.You have to burn it into your chip well.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    79 Comments
    also what could be replacement transistors to c1815 and a950
    thx
    Hi
    please send all programs and part details for newer design along with schematic to my email ktel.adapters@gmail.com
    regards
    gotta try this at home!!!!!!
    i have never tried programmin a pic before
    Gotta Try this
    good idea.try try!!I have uploaded all the details with hex file for PIC16F84A.Hope you can work this out well.Good luck!
    Or can u give me programmed ic if yes then contact me at ayan.s73558@gmail.com
    Hi. I want to know how I connect 16f84 to my laptop?
    hi slwthr, what are the things (software and hardware) I need to program my microcontroller and load the hex files?
    well can we make this using atmega 328 or arduino
    if yes please send me the code and circuit to my mail id.
    kumar.bols@gmail.com
    Sir.. I have one 7 Segment display which displays battery voltage.. I have c program file also. Can u modify that program to didplay it as battery percentage thats 0 To 100 Max..if u r ready to help me. I will send the full project to u.. Plz reply to my e-mail id..
    mail.moonlite@gmail.com
