Introduction: Big Bad Vader Log Burner
Back by popular demand.
The last few vader log burners I've made have caused quite a storm. With this one I wanted to go bigger and badder and try and capture more of the original shape and styling.
The bottle I used was a 46kg I think...yeah pretty big...
Step 1: Marking Out
I magic marketed the face and cut the details out using my drill, 10mm bit and angle grinder with 1.2mm blade...I used a few of these!!
The plan was to cut the bottom off and use the lower section of the cylinder for the hood of the helmet.
Step 2: Mouth Detailing
I welded two bolts into the corner of the triangle to add styling.
Step 3: Hinge
I always fit the hinge before cutting the door so I know it'll always hang straight.
Mark out using a marker pen, drill 3mm hole and tap using a 4mm tapping wrench. The hinge is fitted with 4mm x 10mm machine screws.
Step 4: Bridges
One the bridge of the nose I welded a tube which I had split and cut creating more detailing.
Step 5: Thermal Exhaust Ports
I has running low on scrap buys of metal and with school out for the summer I had to improvise.
My first design used 3 scaffolding tubes welded together but I thought is sucked so ended up cutting them off and going with a 6 tier exhaust which I'm much happier with.
Step 6: Weld and Grind
The eyebrow pieces, Cheek detailing and handle are made from the left over cylinder. I also used a large section of the cylinder to create vaders hood.
Once welded I used a flap wheel fitted to my grinder to smooth all rough edges and strip the paint.
Step 7: Daddy Vader
At the side of a regular sized gas bottle you can see the big vader towers over my previous design.
The original is a 13 or 15kg gas bottle, the big one I think was a 46kg.
Step 8: Burn Vader Burn
Before painting with UHT paint I decided to give is a test burn, this will also burn off any of the remaining original paint.
Step 9: Matt Black
I gave vader 2 coats of UHT black paint and it's good to go.
If you like it please vote...thanks for looking...
Grand Prize in the
Metal Contest
Finalist in the
squeeze more awesome out of summer contest
Great Outdoors Contest
