Introduction: Big Egg + Arduino +IR Sensor = EasterEgguino
About: Retired Math teacher who needs a hobby! So I tinker with stuff: Arduino, welding, my 1958 TR-3 , my tennis serve
I was looking for a way to use a servo and an IR sensor and came up with this project.
The egg contains candy and when a candy seeking person gets close enough, the LEDs will chase and the top part of the egg opens. It remains open for about 3 seconds and then closes.
I used an Ardweeny and all the wiring is just bread boarded instead of soldering everything together. I may yet do that .
Step 1: Stuff Needed
The main items used are:
1. Ardweeny   -   a small Arduino compatible Microcontroller from Solarbotics ..  This is inexpensive but you are required to solder the pieces to the included PCB.
2. A small hobby servo - I used a Futaba GWS03n
3. an IR sensor - I used a Sharp GP2Y0A -
4. you will need the cable that goes to the sensor also
5. 8 Leds
6. 74HC595 shift register to do the LED chasing.
7. 7805 voltage regulator
8. AC adapter to provide the 9 volt current required
9. A big egg(and some smaller ones) - from the Hobby Lobby.
Also
1. hot glue
2. some decorative items - the ears,eyes from a hobby shop or a toy store
3. wire, soldering iron
Step 2: Build the Egg Part
1.   hot glued 3 of the smaller eggs to the bottom to form a base.  Using tape to hold in place worked well.
2.    added a hinge to attach the top part to the bottom part.
3. Cut a piece of scrap wood to fit inside the egg. This is screwed to the egg and will be used to mount the servo.
4. glue a smaller piece of wood to the semi-circular piece.  Attach the servo to the smaller piece with a zip tie.
5. cut another scrap piece of wood into a circle which fits nicely near the bottom of the egg.  The bread board and battery will be mounted on this.  Hot glue this in place .
6. Make an arm for the servo.  This will depend on where you place the servo, size of egg.  I cut a pice out of an old CD case and spray painted it black.
7. attached the IR sensor to what would become the front .
8. need to cut a piece which fits in the egg but just a couple of inches down.  This becomes the shelf upon which the candy will be placed.
Step 3: The Electronics Part
1. The Ardweeny
This comes as a kit from Solarbotics. It includes instructions on how to assemble.
Once assembled it can be used right on the bread board which is what I did.
Connections that need to be made to the Arduino are:
IR sensor
black wire to gnd
red wire to 5v
yellow wire to analog pin 0
Servo
- I have tried to power the servo in various ways but it seems it needs its own power so I
provided 3 AA batteries for power
black wire to gnd
red wire to batteries
white wire to digital pin 9 on ardweeny
- I wanted to have the LEDs chase but did not know how to do this. I found the following
http://www.arduino.cc/en/Tutorial/ShiftOut
I followed the instructions there and it worked.
I must admit I am not completely sure how it works but it does work.
Some other issues:
- had to play around with the servo locations to get it to open but not open too far or not enough
- used a routine" millis"  to give the appearance of the chaser working continuously as the lid opens.
(first video was before this refinement and you will see the chasing does not work but once)
- I power the Ardweeny with an AC adapter . I had hoped I could use it to avoid all batteries but when I try to include the servo , it just is not enough power to open the lid.   I do not know how long the batteries will last.
Step 4: The Code
Below is the code I used :
I started with the servo sweep example and added to it .
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
// modified 4/11 c. dubois
// Made a candy server from a big plastic egg
// idea:
// IR sensor will tell when a hand reaches for the egg and will
// signal servo to open the egg.
// shift register is used to do a LED chase when the egg opens
// updates
// v3 - 4/24/11  add routines to get LEDS to  chase continually
#include <Servo.h>
// distance sensor
 int sensePin = 0;
// Servo
 Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
// 74HC595 shift register
 //Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
// other variables
int ledToDisplay;
int posServo;
long previousMillis = 0;        // will store last time Chase  was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000;           // interval at which to blink (milliseconds)
void setup()
   //set pins to output so you can control the shift register
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
//   Serial.begin(9600);
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
void loop()
  // read the sensor
  // if getting close , thwn want to open the egg and start the leds.
  //  Leds will continue to chase until egg closes
  int val = analogRead(sensePin);
//  Serial.println(val, DEC);
//   map the val to a servo position - pos
// int val = analogRead(0);
//   pos = map(val, 0, 1023, 0, 100);
// open egg and turn on LEDs if close
  if(val > 225)
  // 2. open egg
  posServo = 0;
   for(posServo = 0; posServo < 24; posServo += 1)  // goes from 0 degrees to 65 degrees
     // keep chase going
  runChase();
  // move servo
       myservo.write(posServo);              //  open top, wait 4 secs, close top and wait 5 secs
     delay(25);
 // run a loop for 3 seconds to avoid using delay
 for (long xx=0; xx <= 200000; xx++){
     // keep chase going
  runChase();
    // close the lid
     for(posServo = 24; posServo >=0; posServo -= 1)  // goes from 0 degrees to 65 degrees
       // keep chase going
  runChase();
  // move servo
    myservo.write(posServo);       // then can read again
    delay(25);
  else
    myservo.write(0);              // tell servo to go to position in variable 'pos'
    delay(25);
// my Functions
void ledChase ()
   // 1. chase leds
     for (int n = 1; n < 9;   n++ ) {
        ledToDisplay = pow(2,n) ;
    // take the latchPin low so
    // the LEDs don't change while you're sending in bits:
 //   Serial.println(n);
 //   Serial.println(ledToDisplay);
 //    delay(1500);
    digitalWrite(latchPin, LOW);
    // shift out the bits:
    shiftOut(dataPin, clockPin, MSBFIRST, ledToDisplay);
    //take the latch pin high so the LEDs will light up:
    digitalWrite(latchPin, HIGH);
    // pause before next value:
    delay(50);
    // now chase back in other direction
 //    delay(1500);
    shiftOut(dataPin, clockPin, LSBFIRST, ledToDisplay);
    delay(50);
void runChase ()
   unsigned long currentMillis = millis();
   if(currentMillis - previousMillis > interval) {
  ledChase();
  previousMillis = currentMillis;
Step 5: All Done - Another Video
This shows the insides and the LED chase working.
