Step 14Floor supports
Now we're going to put in 4 stems that will support the plywood floor. If you say to yourself, "I don't need floor supports, plywood is strong enough by itself," you will probably be finding a you-shaped hole in your floor pretty soon, and a you-shaped person on the floor, sheepishly rubbing your painful you-butt.
First, measure the distance between the inside of the two cross-stalks(these are the stalks that are at the height you decided your floor should be). Cut four stems to this length.
The best way I found to put these stems in is to line up the stem so that it's flush with the cross-stalk . A friend really helps with the alignment process, but it's possible solo. (I did all the loft construction by my lonesome, with the exception of wrangling the plywood up the stairs. My neighbor Diego helped me with that. More about Diego later...)
Anyway, line up your stem with the stalk. Remember that you're putting 4 stems in, so space them evenly. Be sure to put two of the stems at either end of the loft.
The best way I found to attach the stem was to put two lag screws running through the cross-stalk running at a slight angle into the stem. That's two lag screws everywhere a stem attaches to a stalk, and it's holding together well so far. I'll let you know if there's ever a me-shaped hole in anything....
(this next bit is talking about the picture, ok?)
Remember how I don't really know how to do anything? When I built this, I didn't realize I needed two more floor supports at the ends of the loft, which is why there's only two there. I put in my floor supports way later. Don't make my mistakes, man!
comment
Add Comment
Add Comment
