Step 19The last time you'll ever use a circ saw
Now, kinda shove or tilt the unmarked sheet out of the way. Make sure it's stable, because you're about to climb up and saw stuff, and you don't want it sliding into you while you're sawing.
Now, I climbed onto the loft, being sure to stay on the supports, and circsawed the marked sheet along the line I marked. This was probably way more dangerous than it should have been. The prudent reader will take the plywood off of the loft, set it up on sawhorses, and cut it in a safe and sane manner.
Anyway, now that you've cut up one of the sheets, they should fit flushly on your floor supports.
Are you excited? You're almost done!
Right after I took this picture was when I realized I needed those inter-stem braces. See how the plywood's drooping here? yuck!
Add Comment
