Step 2*Optional Step*
iImage Information
In this step you will be replacing the internal speaker in your TV with an external one. Don't attempt this if you feel uncomfortable taking things apart. I take no responsibility if you butcher your TV. With that said lets begin. Since your TV is going to be inside a box the sound could become muffled, but if you don't mind this then you may skip this step as it is non-essential. First thing to do make sure your TV is unplugged. I learned the hard way, don't repeat my simpleton mistakes, unless your into the electrical shock thing. Most TVs will have a case that is split into two sections, one part surrounding the front and another part covering the rear. You want to remove the back panel, I've circled the three screw locations on my TV in red. Your TV will most likely be different. Now you should see the innards of your TV. Don't be intimidated by the mess of circuitry and wires, you're only concern is to locate the speaker within the case. There should be a red and white wire running from the back of the speaker, you need to snip it and strip it. Be careful not to cut any other wires, as you can see from the pictures I went a little scissor happy and ended up killing the IR receiver (the blue and white wires), rendering the remote control useless. Now feed the wire you snipped through a hole in the case. Mine had vents on the bottom wide enough to slip the wire through. Now attach the speaker wire to the wire from the TV (red to red, white to white [or black depending on your wire]), and wrap it in electrical tape just to be safe. You don't wanna have to go back into the case because the wire came loose. Good job, now stitch your patient back up. Carefully place the case back onto the TV making sure the screw holes all line up correctly.
