3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bike Blender
Step 2Gain access to the mechanical insides
I did this using a hand drill and unscrewing the bottom. At times I had to find a hand drill with a longer neck to be able to reach the screws which were sometimes several centimeters within the plastic casing.
Sometimes the screws are concealed behind the rubber feet of the blender. Pry them out if you can't see any other access points and just to be sure there are not any extra screws behind them holding the casing in place.
Once the cover was removed, I was met with a second thick black plastic casing around the mechanical parts surrounding the blender shaft. This was also secured on by screws. I unscrewed it working odd and extreme angles due to the outer plastic case. Just bare with it and remove the wires from all the orifices : the buttons should come right out and once out you can work your drill through one of the buttons to be able to unscrew the black casing around the mechanical parts. Basically get creative and do whatever it takes to get the black casing off. Push, pull, twist - these things are pretty rugged and the plastic will take quite a bit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ksutherland
