3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bike Dynamo
Bike Dynamo
'A simple bike dynamo using a motor as a generator.
WARNING becareful not to get any of the parts from this project caught up in your bike. This dynamo can put out more than 12 volts becareful with your parts or they could get blown.
Materials:
1 motor 4v (higher voltage is better)
strong plastic lid
hose clamp looks like a metal circle which can be loosend and tightend. choose one to the size of your motor and the size of the bar on your bike.
something electronic like a bulb or buzzer you can test your dynamo on.
Step 1Attatching the hose clamp.
Attatch the hose clamp around the bar of your bike put your motor in so it is touching either the tyre or rim. Make sure it stays firmly. If not try wedging something imbetween the motor and bar. See below for more details.
43 comments
1-40 of 43next »
Apr 12, 2012. 9:35 PMLakpahana says:
thanks man keep it up
how to amplify current gain
Jan 27, 2011. 10:43 AMJumpStart says:
Download SketchUp at Sketchup.google.com for a quick way to draw your bike- and your dynamo! Good luck and Thank you!
Oct 6, 2010. 8:30 PMlordgarion514 says:
Definition of generator:
Engine that converts mechanical energy into electrical energy by electromagnetic induction. So you see, if you turn the motor it becomes a generator.
Also in many cases you have to initially spin the electric motor a little faster than what it turns when you give it power to sort of "kick start" the generation of electricity. But not always.
Jan 17, 2007. 6:41 AMpyrokid says:
Very good. I can see how it might be a problem to fine-tune one of these, though. I was going to make one of these, but I couldn't figure out how to attach it. Did you get your idea from Tetranitrate's Lego motor generators too?
Mar 29, 2009. 4:22 PMluigi2999 says:
u might wanna add a diode, so that when stopped, the motor dosen't attempt to turn.
Jan 17, 2007. 5:12 PMpyrokid says:
Yeah, I basically meant the comments too. you have a very good idea clamping it there with something, i was trying to figure out how to attach it but i had no idea how to. this gave me some very good ideas. Again, great instructable.
Oct 22, 2008. 9:38 PMthepaul1993 says:
is there a way of telling how much power you get out of it? like with a 3v motor will you only get a max of 3v?
Dec 26, 2008. 5:11 PMrotf101 says:
the higher rating a generator has, the more voltage you'll get out of it, but you'll probably never get 3v out of a 3v generator, unless you can rotate the axle as fast as 3v of power can turn the axle. i hooked up a 3v generator from a hand-held fan to my bike, and could only get about 1v power even at top speed. if you want the axle to turn faster, you'll need a series of gears.
Mar 27, 2009. 10:46 AMsnowpenguin says:
It's NOT a generator, but a motor. Please, stop giving false information to people.
Mar 27, 2009. 6:11 PMrotf101 says:
ah hah. sorry about that. it is technically a motor, but it does put out a voltage if you rotate the axle.
Dec 28, 2008. 1:57 AMthepaul1993 says:
thanks man great help :)
Jul 11, 2008. 3:53 PMYerboogieman says:
(removed by author or community request)
Mar 27, 2009. 10:49 AMsnowpenguin says:
A big enough motor will, yes.
Apr 25, 2008. 6:38 PMinneedofhelp says:
Im trying to run my electric scooter using bike generator(dynamo) but wont work is there any other way pleasssse helllp me?
Jun 20, 2008. 12:16 PMRetroboy4 says:
Do you mean to trickle charge your battery off the Dynamo or Full on run it off the generator? If A) you want to trickle charge the battery, it will charge verrry slowly so don't expect a huge increase in ride time. Or B) If you are try to run the scooter off of it with no battery, it isn't going to work. The Dynamo would have to be at lease 100% efficient, which is impossible to at this time.
Mar 27, 2009. 10:48 AMsnowpenguin says:
Also, trying to move something with electricity generated by it moving won't work. It has to move to get the electricity to move.
Nov 21, 2008. 3:59 PMhyrulianshinobi333 says:
your right 100% is impossible that way by definition due to resistance i.e. friction, but electric heaters are 100% efficient by deffinition because their only purpose is to ecounter resistance cool huh
Jan 30, 2008. 10:29 AMnf_x20 says:
hello i tried this with a 9v motor from a cd drive, attached wires to it and ran it to a flashlight bulb, however it does not work when i turn the wheel of my bike. Could someone help please?
Jan 21, 2009. 6:42 AMsjs229 says:
it worked for me when i used a 12v motor and 4 leds connected in paralell connection
May 17, 2008. 4:55 PMTheWelfareWarrior says:
well, I don't think a little motor from a cad drive is going to do much, they are not designed for the current... You could try using a motor out of an old arc car (motor, NOT SERVO) you could also try gluing the plastic cap to the motor to ensure that it is not slipping. try using a smaller lightblub instead of a bigger motor. and my final piece of advice would be to try it riding faster
May 2, 2007. 12:22 PMwhiteboipumas says:
wat is this sposed to do?
Aug 1, 2007. 10:40 PMgirrrrrrr2 says:
generatr electricity while you are riding your bike to power an electronic device...
Nov 2, 2007. 7:47 PMxproplayer says:
or ipod lol
Oct 9, 2008. 7:55 PMgirrrrrrr2 says:
isnt ipod electric? or did it run off of wood in the new update?
Oct 9, 2008. 8:23 PMxproplayer says:
i meant electric
Apr 15, 2007. 4:46 PMpharoah says:
You could just duct-tape. BTW Fat Bagel you spelled tire wrong in your instructable :)
Jun 25, 2008. 9:00 AMcbelectron says:
Not in the Queen's English he didn't!
Sep 6, 2008. 10:49 AMpharoah says:
Lol, never realized it was spelled that way across the pond. :)
Aug 21, 2008. 3:32 PMrae23 says:
that is truly a work of art
Aug 1, 2008. 7:44 AMHandsome-Ryan says:
Shouldn't you use a [Example Voltage Regulator] when building something like this?
Jul 24, 2008. 6:59 PMandrew_29 says:
dude its a fork not a bar
Apr 25, 2008. 6:41 PMinneedofhelp says:
i hooked up diod bridge and a capasitor to my dynamo so the output would be 12vdc then hooked it up to my motor and test drive but no power?
Apr 21, 2008. 4:21 PMelescape says:
Not sure if it's been said but you could always wire up head lights and tail lights for night riding.
Oct 6, 2007. 5:25 AMpinoymale says:
Is the general idea to have the lid come into contact with the tire/rim so that when the tire/rim spins, it also spins the lid?
Aug 21, 2007. 6:53 PMPazzerz says:
Go to your nearest Lowes or Home Depot and get a spring loaded mini hinge. Attach the motor to the hinge and the hinge to the frame. The spring loading will keep it against the tire. I used to have a headlight system on my bike when I rode as a kid and it worked exactly like this.
Aug 16, 2007. 5:00 PMsam_rocks321 says:
This worked very well i made it in 1/2 hour with a small motor from a cd-rom drive, a hose clamp and a sprite top Great instructable
Jul 13, 2007. 9:31 PMKD7WHQ says:
A DC motor will generate electricity no matter which direction it is turned, or the lead connections...unless there is a diode actually inside the motor itself. Spin it one way, you get electricity. Spin the other, you get same at reverse polarity..
Jun 23, 2007. 10:55 AMSacTownSue says:
To keep things from moving around and shaking loose try putting something rubbery around the motor between the clamp. Something like shelf liner, rug anti skid or how about making rubber bands out of an old bike inner tube. I bet you can find an old bike inner tube without looking too far. Great idea for an instructable. I remember seeing these as a kid and have thought about them since but didn't realize it was so simple. I'm gonna try this.
Mar 2, 2007. 4:05 PMhockeyteeth says:
Add capacitors (they can store energy generated by the dynamo) to the circuit. I don't know how you power anything with the electricity stored in the capacitor, but it would prevent the light from dimming.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Fat Bagel
