3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
NESblinky - Nintendo Controller Bike Flasher
Step 9Flasher Circuit
Flasher Circuit
I was trying to use the simplest LED flashing circuit I could find. The Flip Flop circuit at the bottom of this page seemed perfectly suited: http://www.talkingelectronics.com/projects/FlasherCircuits/Page83FlasherCircuitsP1.html
However, I did not have the right size capacitors, and could not get any capacitor/resistor combination to work. The circuit below shows the values that I used. This was based from the circuit found here: http://www.zen22142.zen.co.uk/Circuits/Misc/flasher.htm
If you have any insight on how to make it work, please let me know. Is it because 2.4-3 V is not enough voltage?
I may give these circuit a try:
http://www.redcircuits.com/Page14.htm
http://www.discovercircuits.com/PDF-FILES/3vledfs1.pdf
http://www.josepino.com/circuits/?transistor_led_flasher.jpc
This circuit is interesting due to it's simplicity and unconventional use of a transistor. However, I do not know if it will work at less the 10V?
I did not have enough time to get the flasher working before I had to leave on a trip, so for now the lights are always on. I will work on the flasher circuit when I return and update the page.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:engineerable
Daniel Bauen breathes new life into objects that have met their untimely demise in the junk pile.
