loading
The is my first attempt at a bike generator and I have made many improvements to the project. Check out my new instructable BikeGen for the new generator which recharges 2 AA batteries and powers the lights. BikeGen can also be used to recharge you cell phone or Ipod
I made this friction drive bike generator to power my head light and tail light. I got the idea and a lot of the info for this project from another great instructable personal powerPlant
I recently bought a bike to commute to work and around town and figured for safety's sake I'd get a light set. This is the light I got, Planet Bike 1200, but there are many options for bike lights. There are many instructables on bike lights too. My lights are both 3V, two AA's in the head light and 2 AAA's in the tail light, and the box said the head light will work for 4 hours and the tail light for 20 hours in blinking mode. While this is respectable it still requires some attention. I got this bike for its simplicity, single speed means I can just hop on and go, but replacing batteries gets expensive and complicates things to much. By adding the generator I can power the lights while riding.
Thanks to instrutables member aaronscottaugustinhotmail.com a schematic of the circuit is also available.
Step 1: Gather the Parts
Your going to need a few things if you want to build a bike generator. Here's what they are:
Electronics:
1x Stepper Motor - I got mine from a printer I got at goodwill for $3
8x Diodes - I used 1N914/4148 from Radio Shack #276-1122, the personal powerPlant used 1N4001, Radio Shack #276-1101
1x Adjustable Voltage Regulator - LM317T, Radio Shack #276-1778
1x Project Box w/PC Board - Radio Shack #270-283
2x Resistors -Radio Shack #271-003 You'll need the 150 Ohm and the 220 Ohm
1x Heatsink - Radio Shack #276-1363
1x Battery Connector - Radio Shack #23-445
18-20 gage solid wire
Electrical tape
You don't have to get everything from the Shack but I find its easier and roughly the same cost as say Jameco or Digi-Key once you pay shipping.
Mechanical:
1x Bike Reflector bracket - I took this off my bike when I put the lights on.
1/2" Aluminum Angle Stock - Both Home Depot and Lowes have this usually in the hardware section or order it from McMaster-Carr #88805K41, You'll need a piece roughly 6in long
Small nuts and bolts - I used the screws from the printer and some other hardware I had, #10-32 machine screws and bolts would be good
Small rubber wheel - This attaches to the stepper motor and rubs against the wheel as it spins. I used a Tamiya 70145 narrow tire because it was what I had.
Tools:
Dremel - This isn't completely necessary but makes things a whole lot easier
Drill and drill bits
File
Screw Drivers, wrenches, allan keys - for the hardware
Solderless Breadboard - Radio Shack #276-003 I used this to test the circuit before soldering everything to the PC Board
MultiMeter
Step 2: Make the Circuit
Now lets make the circuit. Its a good idea to test everything before you start soldering it all together, so I built the whole circuit on the solderless bread board first. I started with the motor connector and the diodes. I desoldered the connector from the circuit board of the printer. Placing the diodes in this orientation changes, or rectifies, the the AC current coming form the motor to DC current that the lights can use. The stepper motor has two coils in it and you need to make sure each coil is wired to one set of the diode groups. To find out which wires from the motor are connected to the same coil you just need to check for continuity between the leads. Two of the wires are connected to the first coil and two of them are connected to the second coil.
Once the circuit was built on the solderless bread board I tested it. The motor produced up to 30 volts while riding the bike normally. It is a 24volt stepper so this seems reasonable. With the voltage regulator installed the output was a constant 3.10volts. This was the plan. The resistors control the output voltage and the 150 and 220 Ohm resistors were chosen to get 3.08volts. Check out this LM317 Voltage Calculator to see how it was wired up.
Now it just need soldered to the PC board. I used small gage solder to make all the connections. It heats up faster and allows for better connections that only bridge where you want them to.
The .pdf's show how everything is connected to the PC Board. The curved lines are the wires shown in some of the pictures and the short black straight lines are were you need to make the solder bridges.
Step 3: Motor Mount
The motor mount was made from the 1/2" aluminum angle and the reflector bracket. Holes were drilled in the aluminum to mount the motor first. Then one side of the angle was cut out to make room for the wheel. The wheel was attached by wrapping electrical tape around the motor's shaft until there was enough to allow the wheel to be forced over the tape. This method works for now but will probably need upgraded in the future.
Once the motor and wheel were attached to the aluminum I found a suitable place on the frame to mount everything. I mounted mine to the seat tube. My bike is a 61cm frame so the area where the generator is mounted is fairly large compared to smaller frame bikes. Just find the best location on your bike to mount the generator.
After I found a good location I marked the aluminum bracket, with the reflector bracket in place, so that it could be cut to size. Then drilled holes in the bracket and the aluminum and mounted the whole thing to the bike.
I then finished everything off by attaching the project box to the aluminum mount with two 1/2" standoffs.
Step 4: Hook everything up
Now all thats needed is to hook it up to the head light. I just pushed the wire ends behind the battery terminals on the head light, then drilled a hole in the light to run the wires through. The wires were then connected to the battery connector. I used this because I wanted to be able to disconnect the the head light quickly. The project box will need slots or holes for the wires for the light and the motor.
Once everything is on go out and ride!
<p>What is this generating and for what purpose please?</p>
<p>Very interesting intractable, why did you choose a stepper instead of a straight DC brushless?</p>
<p>to anyone who understands the electrical components better than I do, is there any circuitry protects against rolling backwards and outputting the reverse polarity from the motor?</p>
<p>With stepper motors there is not polarity like a DC motor, the circuit is made to work in either rotation direction</p>
<p>Oh okay, awesome. <br><br>And what if I only have DC motors? Is there any circuitry I can add to make that work? or do I have to keep trying to find printers to take apart to find a stepper motor I can use <strong>x) </strong>Thanks ahead of time for your patience with my ignorance x)</p>
any advantage of using a stepper motor over a normal DC motor? i think this is the first time i've seen a stepper motor used as a generator...
I've only done a little research into this myself but for starters a stepper motor is brushless, so you don't have losses from friction like in a standard DC motor. This would be very small loss though. I've also read that steppers generate power at much lower rpm's then DC motors. This site, <a rel="nofollow" href="http://www.c-realevents.demon.co.uk/steppers/stepmotor.htm">http://www.c-realevents.demon.co.uk/steppers/stepmotor.htm</a>, claims 10 to 15 times slower rpm than a DC motor. I have not tried to run a DC motor with this generator so I have nothing to compare to though. <br/>
Nice project. Reading comments. Everything could be better but did they build one ? No. They bought one. I built one it was fun still works, but it charges two 1850 cells. Good job, man. If you added a constant current circut and a usb jack instead of the 12v ciggerette light power connector you could easly charge anything usb. and yeah a bit of weather proofing could not hurt. But put your name or nickname somewhere on you project on your bike, your good..
Agreed, found the stepper with full bridges to be an interesting approach that may indeed be more efficient.&nbsp; My suggestion would be to throw in a capacitor as well.<br />
LOL, no it is extremely inefficient because it is generating 30V and you lose 27 volts from use of a linear regulator.&nbsp; That means only 10% electrical efficiency at best, you could randomly pick any other motor with lower output @ same RPM and have it more efficient.<br /> <br /> However, a brushless motor will give longer life due to no brushes to replace, although selecting a motor with high quality ball bearings is another factor to increase lifespan.<br /> <br /> Although use of a linear regulator is very simple for a beginner, it is the wrong circuit to regulate with a human-powered bike generator.&nbsp; The better option would have been a buck switching regulator IC, followed by a LC (inductor, capacitor) filter.&nbsp; Also to increase efficiency you can parallel two schottky diodes in the bridge rectifier.&nbsp;&nbsp; Total circuit cost might be $5 more, but to get roughly eight times the efficiency and lower wheel drag it would be well worth it.<br />
wow ,!!&nbsp; NO REGULATOR ever made would have a loss of 27 volts..<br /> max of about 1.5&nbsp; volt loss.<br /> <br /> or you could even buy a low dropout regulator,,,
Wow, so nice! :D
a better way to go would be using two motors, and or two wheels. i myself am going to try to build one, thanks for the inspiration!
i know were talking about efficiency here, but why not add a digital readout and a power storage device? the digital readout could go on the handlebars so you can see how much power you have and could run more things. you could also add brake lights hooked up to a smaller switch for night. <br><br>very nice build!<br>cheers,<br><br>Occupy
My setup is quite pathetic compared to this, I have a weed whacker motor duct taped to the side of my my bike running against the wheel. I can get about 2 volts spinning it with my hand at least, and thats about 20 times slower than me riding.
You can check out my newest version of this generator, which is able to charge USB devices, here <a href="https://www.instructables.com/id/USB-Bike-Generator/">USB Bike Generator</a>&nbsp;<br> <br> Keep on the look out for a new Instructable I plan on posting later this summer. Its going to be a more robust design that incorporates a standard hub dynamo and USB charging. I plan on putting it to the ultimate test this summer when I ride 1700miles on the <a href="http://www.fullercenter.org/bikeadventure">Fuller Center Bike Adventure</a>
this is just a general question. if i use a 24volt 280 watt, 15.4 amp motor as a generator, will that output 15.4 amps, 280 watts max? how does it translate when you use it as a generator? is it purely based on how much energy (RPMs) you put into it?
The output is based solely on the input power, you pedaling, and the efficiency of the motor as a generator. Your input is product of how fast your spinning (RPM) and how hard your pedaling (torque). You might be able to get 280 watts from the motor but you would be pedaling with over 300 watts(just a guess), this would be a pretty intense workout but still achievable.
I have a question - what kind of stepper motor is it? I tried messing around with one (forgot how many wires it had), and I found that the coils &quot;fought&quot; with one another. i.e., one minute it was rolling smoothly, next thing I wire them together and get the motor resisting movement and low output voltage. How does it get done? A drawing would be really great. XieXie.
A stepper motor is made to move by pulsing electricity through its coils. (usually performed by and oscillator circuit). They are usually used for machines that need high precision positioning. They are called stepper motors because they move in very small &quot;steps&quot; very quickly.
<p>Ahem, I'm sorry to spoil the fun of you re-inventing &quot;bike generator&quot;. (Though I like your project..).<br /> <br /> I am Dutch and over here we have a lot of bikes ( 16 Milion people, 20 million bikes). Almost every bike has a &quot;generator&quot; on it to provide electricity for the lights. 6 volts if I am correct.<br /> <br /> for instance: <a href="http://www.bike4travel.nl/product_info.php?products_id=625" rel="nofollow">http://www.bike4travel.nl/product_info.php?products_id=625</a><br /> <br /> You can buy them in standard (heavy trodding on the peddals), or High efficiency ones and cost between 6 and 60 Dollars. <br /> &nbsp;</p>
But where's the fun in that?
Well, that's true. As I said: I like your project and it does look &quot;cool&quot;. Please forgive me for spoiling your fun. I could send you one of ours, so you can do a test between the &quot;old skool&quot; Dutch design and your High Tech solution?
I know that there have been electricity producing devices on bikes for a long time and I'm not trying to re-invent it, but it was fun to work on this and use it. I'm working on a third version of this generator right now and should have a new instructable soon.
I'll hold you to that. ^^ Using components in ways they weren't meant to be used isn't only &quot;fun&quot;, but also a way to learn how to come up with simple solutions to complex problems. Using a stepper as a generator. Using an LED as a light sensor. Making fuses out of strands of wire. Is this inefficient? Maybe. Does it matter? Not in the least bit. It gives people access to technology and solutions that they normally would not have, or be able to afford.
Give me an adress and I will mail t to you. I did not mean to make any &quot;fun&quot; of your work. I do just the same in my line of business. I too use existing technologies for purposes they were not invented for. ( You probably see and use some of my 'inventions' every day). Sir Clive Sinclair is one of my biggest heroes! I do however see my work as 'fun'. (Getting a company to have a meeting on a Sunday over a suggestion what to do with their technology is fun! It is really funny when the first comment is &quot;He wants us to do what? Impossible!&quot;
thanks
Well done, but as others have commented, this could be refined into something better.&nbsp; Unless you live in the desert, waterproofing is a must. Your circuitry will fail in short&nbsp;order, your&nbsp;generator a little later, from water&nbsp;and dirt contamination if you don't take this into account.&nbsp; You can do this easily by using a project box with the&nbsp;lid sealed&nbsp;with a piece of rubber sheet cut from an old&nbsp;inner tube.&nbsp; Encase the motor in a project box so it, too,&nbsp;is protected from the spray from the tire.&nbsp; Also, the motor/generator is too big as you are wasting most of its output power as heat disipated by the linear regulator - good if your purpose is to give yourself more exercise, bad if you want to generate electricity with the least amount of effort expended.&nbsp; I suggest you resize the motor and/or driven wheel so that the motor outputs about 10 volts at, say, 30 MPH, 5 volts at 15 MPH (give or take, these functions are seldom linear), so you'll have efficient&nbsp;light output&nbsp;at all but the slowest riding speeds.&nbsp;&nbsp;You could compensate for slow speeds by adding a super-capacitor stolen&nbsp;from a cheap wind-up radio to augment the low power from your generator.&nbsp; You might even get the light to satay on for 10 or 20 seconds after coming to a complete stop, such as at a traffic light.&nbsp; This might take some experimenting but shouldn't be difficult.<br /> <br /> Finally, a simple spring and catch mechanism to press the driven wheel against the drive wheel (bike tire) and decouple them easily without having to use a screwdriver would be nice.&nbsp; It would also save wear on your tire.
I was wondering if you could generate enough power to light a light, for even a flash, by having a coil run past a magnet without touching it, or vice versa.&nbsp;&nbsp; Any ideas?
<span class="medium_text" id="result_box"><span style="" title="">Well for you project. </span><span style="" title="">I do not understand way you need to rectify the voltage, I believe that AC LEDs would light, and without loss of efficiency by rectification</span></span>
&nbsp;If there is already a rectifier in the bulb itself, then yes the one near the motor connection is not needed, however, IMO, I would still put them in just for safety measures.<br />
I don't want to rain on anyone's parade but &nbsp;I have doubts about the reliability of a stepper motor exposed to the elements, especially the elements to which a bicycle tire is exposed. &nbsp;The motor should be housed in a water-tight box with the shaft sticking through a hole with o-ring seals to protect the bearings and windings from water and dirt that the bicycle tire will throw off as it spins. &nbsp;Maybe a small otter-box could be used to house the motor and electronics. &nbsp;Then all you need is a way to get the wires and motor shaft through the walls without compromising the seal.<br /> <br /> It's a great project - just needs a little more work...<br /> <br /> Maybe you could eliminate the shaft by mounting small magnets on wheel spokes and have pick up coil(s) mounted on the bike frame. &nbsp;It wouldn't be terribly efficient but probably adequate to charge small batteries/capacitors to power the LEDs.<br /> <br /> TD
Sorry for my ignorance, but what are the coil rectifiers for?<br />
The coils are placed next to moving magnets, as the magnets pass you get positive and negative movement of electrons, first it pushes them down the wire, then it pulls them back.<br /> <br /> A diode is a one-way valve for electrons.&nbsp; A full-wave rectifier uses 4 diodes, 2 diodes for negative (one diode on each input), and 2 diodes for positive (also one diode for each input, but facing the other direction)<br /> <br /> The rectifier sends only positive down one output and only negative down the other.&nbsp; This makes the AC (alternating current) into DC (Direct Current).<br /> <br />
Alright, makes since now.&nbsp; Thanks!<br />
&nbsp;i so wish i understood electronics &amp; mechanics!!! <br /> <br /> taking a trip around lake michigan this summer and this would be so handy- i'd mainly like one that would just recharge AA bateries- the gps eats 'em up quick!! but it'd also be nice to be able to charge my ipod too...<br /> <br /> unfortunately, this is all greek to me. ugh. my brain seriously hurts. I DIY when &amp; where I can, but unfortunately with this, i don't have a clue...<br /> <br /> -greezus<br /> greezus@gmail.com<br />
When I was an exchange student in Sweden in 1995, my host family loaned me an old bike... it was probably at least twenty years old, and it had a light on it that was powered by friction from the tire. I wasn't very inquisitive at the time, so I don't know much about it, but I'm pretty sure there was no battery involved. The light was on when I rode, and off when I didn't.
&nbsp;that was probably an old dynamo charger- they used to be really popular- now the company is making them in the hub of the wheel- totally cool!!
Great idea, and I plan to do the same. You proved it works. My addition to the idea 1st -is to remove the circuit board, solder components together and cover with silicon so it becomes part of wiring. 2nd -add a couple super capacitors so the lights will stay on at intersections. 3rd -put the stepper motor closer to the hub, maybe screw a ring to the spokes for the motor to run on. Great work!!
&nbsp;It's been a while since I did anything with capacitors. &nbsp;How would you go about hooking these up? &nbsp; I'm guessing in parallel, in line with the wire running to the light?
Read up on capacitors if your not sure as they can pack a punch if you short them.<br /> Important!!!<br /> Do not charge them with more voltage than they are rated for.<br /> But they will take as many amps as you can peddle into them.<br />
2 supercapacitors 100F, 2.7volt in series, giving 50F at 5.4volts.<br /> these are put in series to give you the voltage for your LEDs.<br /> But you halve the charge capacity.<br />
&nbsp;Great idea! &nbsp;I plan on doing this by the weeks end. &nbsp;I'm thinking I'll run one wire, negative, to the screw under the water bottle holder, giving the bike's chassis a negative charge, much like with automobiles. &nbsp;Then I'll only need to run one wire to lights, maybe a small buzzer... possibly turn signals.
stepper motors can be found here for cheap :D<br /> <a href="http://www.allelectronics.com/make-a-store/category/400600/Motors/Stepper-Motors/1.html" rel="nofollow">http://www.allelectronics.com/make-a-store/category/400600/Motors/Stepper-Motors/1.html</a>
Hey, &nbsp;What If I wanted to use at larger battery with this set up, say a 7.2v, or 9.6v, could you tell you what parts I would need to chage exactly? &nbsp;Thanks
The regulator is variable so it could set it to those voltages. Check out the link on the circuit step.<br />
&nbsp;Hello. I am adding a stepper motor to my bike generator. I was looking at you project and was wondering, what does a heatsink do? I am only 13 so I dont know everything about electronics yet. I know more than a lot of people my age.
Agreed(I'm only 13 too).<br /> A heatsink makes it easier for high amounts of thermal energy to be toned down to a more ideal temperature. Ex. Computer processors create a high amount of heat, so computer companies put heatsinks to cool the processor and circuitry around it(assisted by cooling fans of course).<br />
and it actually improve the overall preformance of the regulator<br />
Of course, Because it is cooled down.<br />
About This Instructable
191,383views
641favorites
License:
Bio: I enjoy building things more than actually using them.
More by Doug Costlow:Pet Feeder Refinish and Stain Wood Siding Bicycle Cargo Trailer
Add instructable to:
