3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bike Generator
Bike Generator
The is my first attempt at a bike generator and I have made many improvements to the project. Check out my new instructable BikeGen for the new generator which recharges 2 AA batteries and powers the lights. BikeGen can also be used to recharge you cell phone or Ipod
I made this friction drive bike generator to power my head light and tail light. I got the idea and a lot of the info for this project from another great instructable personal powerPlant
I recently bought a bike to commute to work and around town and figured for safety's sake I'd get a light set. This is the light I got, Planet Bike 1200, but there are many options for bike lights. There are many instructables on bike lights too. My lights are both 3V, two AA's in the head light and 2 AAA's in the tail light, and the box said the head light will work for 4 hours and the tail light for 20 hours in blinking mode. While this is respectable it still requires some attention. I got this bike for its simplicity, single speed means I can just hop on and go, but replacing batteries gets expensive and complicates things to much. By adding the generator I can power the lights while riding.
Thanks to instrutables member aaronscottaugustinhotmail.com a schematic of the circuit is also available.
Step 1Gather the Parts
Gather the Parts
Your going to need a few things if you want to build a bike generator. Here's what they are:
Electronics:
1x Stepper Motor - I got mine from a printer I got at goodwill for $3
8x Diodes - I used 1N914/4148 from Radio Shack #276-1122, the personal powerPlant used 1N4001, Radio Shack #276-1101
1x Adjustable Voltage Regulator - LM317T, Radio Shack #276-1778
1x Project Box w/PC Board - Radio Shack #270-283
2x Resistors -Radio Shack #271-003 You'll need the 150 Ohm and the 220 Ohm
1x Heatsink - Radio Shack #276-1363
1x Battery Connector - Radio Shack #23-445
18-20 gage solid wire
Electrical tape
You don't have to get everything from the Shack but I find its easier and roughly the same cost as say Jameco or Digi-Key once you pay shipping.
Mechanical:
1x Bike Reflector bracket - I took this off my bike when I put the lights on.
1/2" Aluminum Angle Stock - Both Home Depot and Lowes have this usually in the hardware section or order it from McMaster-Carr #88805K41, You'll need a piece roughly 6in long
Small nuts and bolts - I used the screws from the printer and some other hardware I had, #10-32 machine screws and bolts would be good
Small rubber wheel - This attaches to the stepper motor and rubs against the wheel as it spins. I used a Tamiya 70145 narrow tire because it was what I had.
Tools:
Dremel - This isn't completely necessary but makes things a whole lot easier
Drill and drill bits
File
Screw Drivers, wrenches, allan keys - for the hardware
Solderless Breadboard - Radio Shack #276-003 I used this to test the circuit before soldering everything to the PC Board
MultiMeter
186 comments
1-40 of 186next »
Jan 23, 2012. 7:59 AM#OccupyInstruct says:
i know were talking about efficiency here, but why not add a digital readout and a power storage device? the digital readout could go on the handlebars so you can see how much power you have and could run more things. you could also add brake lights hooked up to a smaller switch for night.
very nice build!
cheers,
Occupy
Jul 14, 2011. 12:20 PM_Scratch_ says:
My setup is quite pathetic compared to this, I have a weed whacker motor duct taped to the side of my my bike running against the wheel. I can get about 2 volts spinning it with my hand at least, and thats about 20 times slower than me riding.
Mar 29, 2011. 7:53 AMwagman45 says:
this is just a general question. if i use a 24volt 280 watt, 15.4 amp motor as a generator, will that output 15.4 amps, 280 watts max? how does it translate when you use it as a generator? is it purely based on how much energy (RPMs) you put into it?
Jun 17, 2010. 11:00 AMUdon says:
I have a question - what kind of stepper motor is it? I tried messing around with one (forgot how many wires it had), and I found that the coils "fought" with one another. i.e., one minute it was rolling smoothly, next thing I wire them together and get the motor resisting movement and low output voltage. How does it get done? A drawing would be really great. XieXie.
Jul 17, 2010. 10:39 AMmartzsam says:
A stepper motor is made to move by pulsing electricity through its coils. (usually performed by and oscillator circuit). They are usually used for machines that need high precision positioning. They are called stepper motors because they move in very small "steps" very quickly.
May 18, 2010. 10:37 AMilwgjh says:
Ahem, I'm sorry to spoil the fun of you re-inventing "bike generator". (Though I like your project..).
I am Dutch and over here we have a lot of bikes ( 16 Milion people, 20 million bikes). Almost every bike has a "generator" on it to provide electricity for the lights. 6 volts if I am correct.
for instance: http://www.bike4travel.nl/product_info.php?products_id=625
You can buy them in standard (heavy trodding on the peddals), or High efficiency ones and cost between 6 and 60 Dollars.
Jun 17, 2010. 10:56 AMUdon says:
But where's the fun in that?
Jun 24, 2010. 3:45 PMilwgjh says:
Well, that's true. As I said: I like your project and it does look "cool". Please forgive me for spoiling your fun. I could send you one of ours, so you can do a test between the "old skool" Dutch design and your High Tech solution?
Jun 25, 2010. 5:21 AMUdon says:
I'll hold you to that. ^^ Using components in ways they weren't meant to be used isn't only "fun", but also a way to learn how to come up with simple solutions to complex problems. Using a stepper as a generator. Using an LED as a light sensor. Making fuses out of strands of wire. Is this inefficient? Maybe. Does it matter? Not in the least bit. It gives people access to technology and solutions that they normally would not have, or be able to afford.
Jun 26, 2010. 2:34 PMilwgjh says:
Give me an adress and I will mail t to you. I did not mean to make any "fun" of your work. I do just the same in my line of business. I too use existing technologies for purposes they were not invented for. ( You probably see and use some of my 'inventions' every day). Sir Clive Sinclair is one of my biggest heroes! I do however see my work as 'fun'. (Getting a company to have a meeting on a Sunday over a suggestion what to do with their technology is fun! It is really funny when the first comment is "He wants us to do what? Impossible!"
May 21, 2010. 9:14 PMmha1363 says:
thanks
May 18, 2010. 5:12 AMkmpres says:
Well done, but as others have commented, this could be refined into something better.  Unless you live in the desert, waterproofing is a must. Your circuitry will fail in short order, your generator a little later, from water and dirt contamination if you don't take this into account.  You can do this easily by using a project box with the lid sealed with a piece of rubber sheet cut from an old inner tube.  Encase the motor in a project box so it, too, is protected from the spray from the tire.  Also, the motor/generator is too big as you are wasting most of its output power as heat disipated by the linear regulator - good if your purpose is to give yourself more exercise, bad if you want to generate electricity with the least amount of effort expended.  I suggest you resize the motor and/or driven wheel so that the motor outputs about 10 volts at, say, 30 MPH, 5 volts at 15 MPH (give or take, these functions are seldom linear), so you'll have efficient light output at all but the slowest riding speeds.  You could compensate for slow speeds by adding a super-capacitor stolen from a cheap wind-up radio to augment the low power from your generator.  You might even get the light to satay on for 10 or 20 seconds after coming to a complete stop, such as at a traffic light.  This might take some experimenting but shouldn't be difficult.
Finally, a simple spring and catch mechanism to press the driven wheel against the drive wheel (bike tire) and decouple them easily without having to use a screwdriver would be nice.  It would also save wear on your tire.
May 17, 2010. 9:52 AMthepelton says:
I was wondering if you could generate enough power to light a light, for even a flash, by having a coil run past a magnet without touching it, or vice versa.   Any ideas?
Feb 14, 2009. 6:30 AMpjax says:
any advantage of using a stepper motor over a normal DC motor? i think this is the first time i've seen a stepper motor used as a generator...
Jan 9, 2010. 12:47 AMGTechno13 says:
Agreed, found the stepper with full bridges to be an interesting approach that may indeed be more efficient.  My suggestion would be to throw in a capacitor as well.
May 16, 2010. 11:32 AMac-dc says:
LOL, no it is extremely inefficient because it is generating 30V and you lose 27 volts from use of a linear regulator.  That means only 10% electrical efficiency at best, you could randomly pick any other motor with lower output @ same RPM and have it more efficient.
However, a brushless motor will give longer life due to no brushes to replace, although selecting a motor with high quality ball bearings is another factor to increase lifespan.
Although use of a linear regulator is very simple for a beginner, it is the wrong circuit to regulate with a human-powered bike generator.  The better option would have been a buck switching regulator IC, followed by a LC (inductor, capacitor) filter.  Also to increase efficiency you can parallel two schottky diodes in the bridge rectifier.   Total circuit cost might be $5 more, but to get roughly eight times the efficiency and lower wheel drag it would be well worth it.
May 16, 2010. 4:13 PMkrawczuk says:
wow ,!!  NO REGULATOR ever made would have a loss of 27 volts..
max of about 1.5  volt loss.
or you could even buy a low dropout regulator,,,
May 16, 2010. 1:09 PMAlquimista says:
Well for you project. I do not understand way you need to rectify the voltage, I believe that AC LEDs would light, and without loss of efficiency by rectification
May 16, 2010. 2:31 PMKT Gadget says:
 If there is already a rectifier in the bulb itself, then yes the one near the motor connection is not needed, however, IMO, I would still put them in just for safety measures.
May 16, 2010. 12:24 PMBTTFfan96 says:
Dude, Awesome! I'm Going 2 Try This!!!    =P
PS-Wish Me Luck!!!
May 16, 2010. 11:31 AMMark Rehorst says:
I don't want to rain on anyone's parade but  I have doubts about the reliability of a stepper motor exposed to the elements, especially the elements to which a bicycle tire is exposed.  The motor should be housed in a water-tight box with the shaft sticking through a hole with o-ring seals to protect the bearings and windings from water and dirt that the bicycle tire will throw off as it spins.  Maybe a small otter-box could be used to house the motor and electronics.  Then all you need is a way to get the wires and motor shaft through the walls without compromising the seal.
It's a great project - just needs a little more work...
Maybe you could eliminate the shaft by mounting small magnets on wheel spokes and have pick up coil(s) mounted on the bike frame.  It wouldn't be terribly efficient but probably adequate to charge small batteries/capacitors to power the LEDs.
TD
Jan 3, 2010. 8:25 PMMattPendley says:
Sorry for my ignorance, but what are the coil rectifiers for?
May 16, 2010. 9:44 AMnubie says:
The coils are placed next to moving magnets, as the magnets pass you get positive and negative movement of electrons, first it pushes them down the wire, then it pulls them back.
A diode is a one-way valve for electrons.  A full-wave rectifier uses 4 diodes, 2 diodes for negative (one diode on each input), and 2 diodes for positive (also one diode for each input, but facing the other direction)
The rectifier sends only positive down one output and only negative down the other.  This makes the AC (alternating current) into DC (Direct Current).
May 16, 2010. 11:04 AMMattPendley says:
Alright, makes since now.  Thanks!
May 16, 2010. 8:18 AMgreezus says:
 i so wish i understood electronics & mechanics!!!
taking a trip around lake michigan this summer and this would be so handy- i'd mainly like one that would just recharge AA bateries- the gps eats 'em up quick!! but it'd also be nice to be able to charge my ipod too...
unfortunately, this is all greek to me. ugh. my brain seriously hurts. I DIY when & where I can, but unfortunately with this, i don't have a clue...
-greezus
greezus@gmail.com
Dec 10, 2008. 4:39 PMJordanaG says:
When I was an exchange student in Sweden in 1995, my host family loaned me an old bike... it was probably at least twenty years old, and it had a light on it that was powered by friction from the tire. I wasn't very inquisitive at the time, so I don't know much about it, but I'm pretty sure there was no battery involved. The light was on when I rode, and off when I didn't.
May 16, 2010. 7:55 AMgreezus says:
 that was probably an old dynamo charger- they used to be really popular- now the company is making them in the hub of the wheel- totally cool!!
Sep 6, 2009. 8:29 PMgordoflash says:
Great idea, and I plan to do the same. You proved it works. My addition to the idea 1st -is to remove the circuit board, solder components together and cover with silicon so it becomes part of wiring. 2nd -add a couple super capacitors so the lights will stay on at intersections. 3rd -put the stepper motor closer to the hub, maybe screw a ring to the spokes for the motor to run on. Great work!!
May 3, 2010. 1:52 AMsean882 says:
 It's been a while since I did anything with capacitors.  How would you go about hooking these up?   I'm guessing in parallel, in line with the wire running to the light?
May 3, 2010. 2:24 AMgordoflash says:
Read up on capacitors if your not sure as they can pack a punch if you short them.
Important!!!
Do not charge them with more voltage than they are rated for.
But they will take as many amps as you can peddle into them.
May 3, 2010. 2:19 AMgordoflash says:
2 supercapacitors 100F, 2.7volt in series, giving 50F at 5.4volts.
these are put in series to give you the voltage for your LEDs.
But you halve the charge capacity.
May 3, 2010. 1:51 AMsean882 says:
 Great idea!  I plan on doing this by the weeks end.  I'm thinking I'll run one wire, negative, to the screw under the water bottle holder, giving the bike's chassis a negative charge, much like with automobiles.  Then I'll only need to run one wire to lights, maybe a small buzzer... possibly turn signals.
Mar 23, 2010. 9:05 AMjwcheatwood says:
Feb 10, 2010. 9:43 PMrpvanpatt says:
Hey,  What If I wanted to use at larger battery with this set up, say a 7.2v, or 9.6v, could you tell you what parts I would need to chage exactly?  Thanks
Jan 12, 2010. 2:15 PMTOCO says:
 Hello. I am adding a stepper motor to my bike generator. I was looking at you project and was wondering, what does a heatsink do? I am only 13 so I dont know everything about electronics yet. I know more than a lot of people my age.
1-40 of 186next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:dbc1218
I enjoy building things more than actually using them.
