3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bike Lock Holder
Bike Lock Holder
  • last photo ←
Hear is a neat and easy way to make a bike lock holder that stays on your bike.
more specifically this is for the U-Bolt type bike locks.
the cable ones, you can usually just wrap around the seatpost,
but the U-bolt are a little more difficult to carry around while your biking.
this can be built for around $3.50 (less if you already have some of the parts) and take about 10 minutes.
Step 1Materials and Tools
Materials and Tools
You will need
-one foot section of PVC (for my lock i used 1 1/4" pipe, but it may ne different for your lock)
-2 hose clamps
tools:
-saw
-sharpie
-3/4" drill bit
-drill
-clamp (not required, but helpful)
19 comments
Jan 20, 2007. 3:26 PMChrisCanMake says:
Great Instructable! thanks!
Just a note for those thinking of making this ulock holder:
IT ONLY works for locks with the keys that fit into the END of the lock "bar" (the part where the lock mechanism is.)
With both my newer cyclinder key and flat key locks, the key enters the lock perpendicluar to the "lock bar".. so this design won't work (as the key would have to morph through the PVC tube AND would end up in the bikes crossbar!) SEE ATTCHED PICTURE
HOWEVER, i'm working on a mod for this design (since its pretty slick) to accomidate this type of lock. i'll put it up soon =)
Aug 25, 2008. 5:11 PMjaime9999 says:
Here's a variation of the Bike Rack Holder for owners of newer U-Locks-- - mount the tube to the side of your Bike's Top Tube (requires a mounting that won't slip down to the bottom-- perhaps using blocks of rubber, or epoxy). - thread one LEG of the U, not the shackle, of the lock through the tube. (no holes are needed in the tube, though perhaps notches are helpful to limit movement). Thus, the lock sits in the tube like a sideways U (more like a C). That leaves the entire shackle out in the air, where you can lock it. Alternatively, mount the tube on the Seat Tube (vertically, and then the lock can hang in a U or inverted U shape, though you'd need to find position where you could insert the lock without hitting the crank or the bottom of the frame. The previous-generation Kryptonite mounting brackets worked this way, which is brilliant- use the lock's own locking ability to secure the lock to the bracket. Kryptonite added a spline to both the tube and a little part that secured onto the shackle, to prevent the lock from moving around too much.
Sep 4, 2010. 4:01 AMbo88y says:
Here's another alternative for using this concept when the keyhole is located on the side of the bar instead of the end, using the same pipe, installed the same way.
~~ Instead of drilling holes in the pipe for the shackle to pass through, make slots that extend 1/4 of the way around the circumference of the pipe, so that the lock can swing 90 degrees to one side when it's in place. Drill another hole through the pipe at the location where the keyhole will be when the lock is swung up to the side. Putting the lock in, and taking it out of this holder takes place in the swung-up position, and gravity will hold it down for the ride.
~~ Given the geometry of the pipe and the crossbar and the key, you probably wouldn't need the full 90 degrees of swing to get access to the keyhole. No sense cutting more than necessary, so make the slots for an 85 or 80 degree swing, and cut the keyhole-hole in the appropriate spot. Each slot is made by drilling a hole at either end and sawing out the space in between with a keyhole saw, first by laying the pipe down and cutting in the usual manner for cutting pipe, and then by slipping the saw into the slit and cutting the rest with short strokes, to avoid cutting past the holes.
~~ If you're worried about the thing flapping around, and are lucky enough to have a bike with a crossbar that inclines upwards at the front, make the slots "L" shaped, by drilling another hole behind the bottom ends of the slots, and connect them by sawing, so that the lock will naturally slide backwards into the place where it can't swing. You could mount this version on the seatpost, too.
Aug 13, 2009. 9:10 PMSkyfinity says:
I have seen so many people that carry their U locks by shoving them down their pants. I have a hard time this is comfortable, effective, or doesn't leave a U shaped mark in the seat of your pants. Though I don't own U bike lock, this is a very good idea, and I may build something similar to hold regular locks. Thanks!
Sep 22, 2007. 4:41 PMkillerjackalope says:
well I recently got sick of having the big industrial strength U lock clanking around the bottom of my headset so first I hit it a hammer to see if I could unstick the mechanism and open it with a key but nay! my effort were no good, 5mins later I had hacksawed a cut just wide enough to jam in a super long flathead screwdriver, bend the bar and open the lock bolt by pulling it open... now there are weaknesses that both locks have however a strong full encased padlock and hardened steel chain wins out if you put 2 links through the lock. the baddies bust their hacksaw cutting one link. unfortunately this option is heavy but a big chain is handy to have around...
Apr 7, 2009. 1:13 PMKactapuss says:
if you put two links through the lock..... wouldn't you just cut ANYWHERE else on the chain and then remove it (lock still locked) and yoink the bike?
Jul 23, 2008. 11:18 PMstncilr says:
negative. because most bike u-locks need you to turn the key to lock it. It is not automatically locked by a spring (like normal padlocks) The shim is only good for locks that are self-locking (that is, the key is not required to lock the padlock).
Sep 12, 2008. 3:22 PMWaddib says:
if your bike has a key hole opposite the connections for the bike lock then drill a third hole right there and mount on top of bar
Nov 14, 2007. 8:08 PMchephy says:
Good idea, but this will only work if the keyhole is on the side of the U-lock's bar, rather than in the middle. Unfortunately, the side design is in general less secure, so it's only used in pretty cheap U-locks these days.
Jul 31, 2006. 6:06 PMtheRIAA says:
..arnt those the ones you can open with a BIC pen?
Jul 16, 2007. 3:32 PMAlmax9633 says:
Bic pen caps are sooo yesterday, no but you can see the Kryptonite Fahgettaboudit chain and Abus Granit City Black X-Plus go with manual bolt croppers in 11 seconds and 6 seconds. Alan thinks they don't use bolt croppers in the real world! In fact this film shot in Europe showing similar tools being used as we used at ITV must be faked!
http://www.youtube.com/watch?v=G1yImVLW_Q0
We only used, silent forms of attack on the ITV show, Bolt croppers and wire cutters. We did not have the miniature bottle jacks at the time of testing, however I have now and they are very very effective at attacking U locks.
If you want to avoid a minuature jack being used on a U lock, make sure you don't leave enough room for a tennis ball. Other wise the miniature jack fits in between both sides of the shackle at the body end, then proceeds to split the body in two.
It makes less noise than opening a crisp packet!
A
Maybe alan is right and the scrotes only steal cycles with non approved locks, or maybe they don't care. Maybe they know, like we have found in the last couple of weeks that most of the stuff approved is little more than a minor inconvenience.
Wake up Alan, scrotes use bolt croppers, wire cutters and miniature bottle jacks. I do feel for you chaps, the selection of approved stuff we tested for ITV was utter crap.
Change however is coming, Sold Secure and Thatcham are going to struggle to wiggle out of this one.
Jul 16, 2007. 1:48 PMAlmax9633 says:
Hi, watch out for ITV (London SE) 24th July 7.30pm or SKY 993! alanbikehouston, with regards to the chap who earlier lost his bike to a Kryptonite 3000 16mm U lock, well if you knew your onions you would have realised that the locks body turns full cirle once the shackle has been cut! You persist in showing little knowledge, the double locking mechanism employed by the Kryptonite does not prevent this! Its a round shackle Ooops! You simply cut one side and twist the body round. Try it yourself, its easy peasy. Some of the Abus stuff employs a square shackle, which is much better than the Kryptonite system! As its a square peg in a square hole, not nice to twist around, unlike the Kryptonite. Now stop sprouting waffle, alanbikehouston and grow up! Alan if you could just get of the Kryptonite band waggon, and look at what we are trying to do. We are trying to get Sold Secure and Thatcham to up their testing standards. You seem however to prefer to see nothing changed! Why?
Jul 2, 2007. 7:57 PMAlmax9633 says:
Eric Stanton Check out www.almax.security.chains.co.uk I aint trying to sell u anthing, contact via the website, urgent! I'm Alex the grey haird chap on the video I would like to find out if U locks and the larger D locks are getting broken by the pro's. I have a very interesting video yet to be released, which involves this exact lock Kryptonite 3000 16mm D lock ( possibly the 18mm as well)
Jul 16, 2007. 10:57 AMalanbikehouston says:
They are not except in very very rare cases, besides you should really try to sell motorcycle locks to motorcycle users Almax. The Almax series 3-4 can be cut in 37 seconds. Maybe you've spent too much time trying to cut the competitions chains instead of making your own strong enough. 37 seconds isn't very long
Jun 14, 2007. 10:33 PMStepsoftheSun says:
Success! Thanks!
Aug 1, 2006. 9:59 PMEric Stanton says:
Cool Idea but like "theRIAA" says a bic pen can open most u-locks.
http://thirdrate.com/kryptonite/ <- just one of many examples.
In all honesty though a lock only keeps honest people honest and there isn't a lock on the market that can't be circumvented easily or defeated by bruteforce of some sort. I have used scissor and bottle jacks to pop off u-locks and cable cutters just dealing with my own bike (I lose my keys quite often.)
Here is a great video for anyone that rides a bike...
http://www.youtube.com/watch?v=5TNTq3nhuh0
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tmiron
