loading
Step 3: Making the Key
What we're aiming for. The split ring attaches to the back and the magnet to the side of the key, they're held on by a glob of shapelock that makes the new key handle.
By using a neodymium magnet with a countersink hole, a conical plug of shapelock in the hole is sure to hold it firmly in place. If you can't find one, try a more-common disk magnet, making sure it's completely covered in the glob of plastic . After all, you can always warm it up and disassemble it to try again.
Important!  Neodymium magnets may loose their magnetism at 80 degrees Celsius. Polycaprolactone only softens at 60 degrees Celsius so you've got to keep the polymer within the 20 degree temperature window when making this. I just put some granules of the plastic in a metal dish and carefully used a hot-air paint stripper to give them the absolute minimum of heat neaded to soften the plastic. Luckily, the stuff goes from white to clear the moment it's ready to use.
If you did not want to use Shapelock, you could use an epoxy putty repair stick--just another option.
True.<br>Although shapelock is easy to rework if you get it wrong - jusy heat it up.
With my Chrome bag I found it lacked areas to latch/thread things into it. On the shoulder strap (where you've placed a key holder) I installed a grommet so I could hook my keys onto it. For the longest time I would use a velchro loop to hook my keys/camelback valve, but I was always scared heavy keys would break the velchro.
Yep... Kryptonite New York. Not as good as a Kryp. Fahgettaboudit, or the top-of-the-line ABUS. But I'm not in an especially high-crime area.
Is that a kryptonite key? it kinda looks like it.
About This Instructable
7,170views
17favorites
License:
More by katsmeat:Bike Lock Key Holder
Add instructable to:
