Step 1: Frame Prep.
- If you only want to sand down the current paint, my favorite method is to use 180grit wet/dry sandpaper. I keep a bucket next to me and rinse off the paper when its starts to clog with old paint. The wet sanding cuts through the paint pretty quick but it still takes awhile.
- I tape off all the holes and trim the excess with an exacto. I stuff a roll of newspaper in the seat tube because I’ve seen motorcycle builders do this so I feel cool. Get decent masking tape that sticks well but doesn’t pull off paint. I have found that the blue house painters tape doesn’t stick well enough for detail work but is fine for masking big areas.
- If you can, wait for a warm, dry day. It will help the paint bond well.
Step 2: Painting.
- I lay down two coats of primer and generally two coats of paint for each color. On the Cannondale I used three for the base tan color.
- I do a light sanding between coats of color with 600grit wet/dry paper. The paper cuts through low spots pretty quick so don’t stay in one area too long. I don’t sand when doing the detail bits.
- I like to use allot of clear for extra protection. Don’t load it up in one big coat, use a couple light coats and let them dry in between.
Step 3: Creative Tips.
- The checkerboard spiral was done using little square stickers I found at the hardware store. They were sheets of numbers in this case. The size of the sticker dictated the pattern size which is why I had a gap left over where I put the Twain quote (when you mess up get creative!). I already had the tan base color so I placed a spiral of stickers where I wanted that color to show through. Then I laid the next color and placed sticker next to the first row. I did this for all the colors until only one row was not covered with stickers and I sprayed the last color. Then I pulled all the stickers off very carefully with the tip of an exacto.
- When doing a pattern you should plan out all your layers and decide what order they need to go in. I could have sprayed all the brown stripes in the plaid at once but that would have made my masking job much harder. I separated them by color and direction and decided that I wanted the white on top.
- One trick that really saved me time was using freezer paper to cover the panels I wasn’t working on at the time. This allowed to panels to dry while I worked on the third. I rotated the paper wraps after I each layer on each tube. I wrapped the freezer paper waxy side in so it wouldn’t stick but I still waited 30 minutes after spraying to wrap a tube.
- For the Mark Twain quote I wrote it on a piece of masking tape to check the sizing. Then I copied it on a piece of carbon paper and lightly traced it on the tube. The ink you see is actually just blue sharpie which turned out kind of metallic on the bike.
- Another thing I like to do for text is use a reverse stencil. After the primer I spray the area where the lettering will go with the color I want it to be. Then I put down some vinyl sticker letters and spray the rest of the bike its final color. When I pull off the stickers I have nice clean lettering showing through in the color I wanted. You can get fancy by having a sticker shop make you a custom window sticker with whatever font or logo you want. Make sure you get the stickers that are letters cut out of vinyl and not a big rectangle with letter printed on it.
- No design is impossible. I thought the plaid would be impossible when I thought of it. Just picture you dream paintjob in you head then try to plan out how you could make it happen. It’s like a puzzle!
Visit Our Store »
Go Pro Today »
Thanks for using instructables!
http://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
cheapest compromise: make base and color using spray cans, and then take the frame for coating to car painting shop.
spraying over powder coating has one more advantage: powder coats are limited to RAL color palette (at least in Poland). you can fill cans (for spray or gun) with every car color possible or have a custom color, with pearl and metalic gloss.
Link to instructable about it.
http://www.instructables.com/id/How-to-make-your-bike-look-like-new-again/
dorm7guard
The 600 will be very smooth paper compared to the 180.
I used an angle grinder with a wire brush to get most of the orginal paint off the bike. I also used an eco friendly stripper that I found at home depot. Next I cleaned the bike and then primed it with a metal primer. Next I would cut a section of wallpaper and modpodge the backside strip of wallpaper and the section of bike frame. Once that dried I would give that section a sealing coat of mod podge.
On the mod podge website it says a woman decoupaged her vw bug w/ mod podge
The topcoat of mod podge does protect it but I decided to also spray it with a high grade clear coat. I think I sprayed it 5 times.
Thanks
