3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bike Painting Tips
Step 3Creative Tips.
Creative Tips.
- The plaid on the Cannondale was done by smoothly wrapping masking tape around the tube. I started the tape at what looked like a 45 degree angle to the tube and rolled it around kind of like bar tape. I did the two brown stripes that face one direction. After it dried I removed the tape and laid new tape perpendicular to the first. I did the same for the thin white stripes but with a smaller gap between tape strips. If your tape stats getting closer together or spreading apart while you wrap you can carefully smooth the opposite edge to guide it back one track
- The checkerboard spiral was done using little square stickers I found at the hardware store. They were sheets of numbers in this case. The size of the sticker dictated the pattern size which is why I had a gap left over where I put the Twain quote (when you mess up get creative!). I already had the tan base color so I placed a spiral of stickers where I wanted that color to show through. Then I laid the next color and placed sticker next to the first row. I did this for all the colors until only one row was not covered with stickers and I sprayed the last color. Then I pulled all the stickers off very carefully with the tip of an exacto.
- When doing a pattern you should plan out all your layers and decide what order they need to go in. I could have sprayed all the brown stripes in the plaid at once but that would have made my masking job much harder. I separated them by color and direction and decided that I wanted the white on top.
- One trick that really saved me time was using freezer paper to cover the panels I wasnt working on at the time. This allowed to panels to dry while I worked on the third. I rotated the paper wraps after I each layer on each tube. I wrapped the freezer paper waxy side in so it wouldnt stick but I still waited 30 minutes after spraying to wrap a tube.
- For the Mark Twain quote I wrote it on a piece of masking tape to check the sizing. Then I copied it on a piece of carbon paper and lightly traced it on the tube. The ink you see is actually just blue sharpie which turned out kind of metallic on the bike.
- Another thing I like to do for text is use a reverse stencil. After the primer I spray the area where the lettering will go with the color I want it to be. Then I put down some vinyl sticker letters and spray the rest of the bike its final color. When I pull off the stickers I have nice clean lettering showing through in the color I wanted. You can get fancy by having a sticker shop make you a custom window sticker with whatever font or logo you want. Make sure you get the stickers that are letters cut out of vinyl and not a big rectangle with letter printed on it.
- No design is impossible. I thought the plaid would be impossible when I thought of it. Just picture you dream paintjob in you head then try to plan out how you could make it happen. Its like a puzzle!
11 comments
May 6, 2008. 12:05 PMjohannalee says:
you could also ask the sticker or sign shops for odd pieces of vinyl. They run huge sheets that come wrapped around a tube through plotters and there's always ends that are usually too small to use for anything. there are a lot of extra pieces lying around our shop all the time. even mis-cut vinyl could be used for some cool paint effects. This is such a cool idea. I've wanted to do this for so long but never really thought about the right way to do it or the right materials to use. Love the plaid. Are there glittery spray paints?
Dec 6, 2011. 5:56 PMtwall3 says:
Yeah, they make aerosol cans of spray glitter. It's basically glitter suspended in a clear coat. I don't think it's super strong itself since it's kind of cheap and not really meant for high abuse jobs like bikes. I used it once on a bike that I was painting white but wanted to have a little metallic shine. I sprayed a coat of white, then a coat of glitter, another coat of white, glitter again, white a final time and then a few coats of clear. It came out pretty sweet, the glitter isn't overbearing but adds a nice touch and it has held up well.
May 27, 2009. 7:57 AMbibamofo says:
It's funny, when I saw the pics of Panda Face's bike, I just assumed that the plaid pieces were printed vinyl. I did something similar with my bike using JavaSigns.com and was pretty pleased with the way the vinyl decals turned out once I was done applying them. Still, I gotta say there's something more impressive about doing it the old fashioned way. Kinda cool to see someone do by hand what I used Illustrator to do. Bravo!
Nov 6, 2011. 2:29 AMbfunnekotter says:
I could not agree more with @fastback570....GET RID OF YOUR TELEVISIONS!
Sep 17, 2009. 2:29 PMfastback570 says:
The plaid Looks great. Check this variation..
Jul 29, 2011. 4:06 PMstymemagnets says:
dabasseb dude!!
May 31, 2011. 8:29 PMBillBiker says:
Wanted to reply to the guy above with the 1964 beach cruiser to say that is an awesome restore job! Also I like this one too!
Apr 5, 2011. 4:25 PMTSC says:
That's cool!
Mar 20, 2011. 11:38 AMHallmar says:
How in the hell did you do that?
Jan 1, 2011. 9:27 PMstruckbyanarrow says:
reminds me of the conago/ futura 2000 collaboration
http://www.flickr.com/photos/55583638@N07/5185855738/
Apr 18, 2010. 1:16 PMshmuley95 says:
 maybe one of the best looking bikes i have ever seen. great job!
Mar 22, 2010. 12:17 PMpoop poop says:
that looks awesome, did you just put pieces of tape half on and half off?
Oct 9, 2009. 4:23 AMKryptonite says:
Wow, nice! How long did that take?
Oct 9, 2009. 5:31 AMfastback570 says:
this is what happens when you don't own a TV,  good stuff.
i don't remember exactly how long it took but i was only gonna do one tube like that at first but i figured what the heck and went all in.  project over a couple days.
Oct 9, 2009. 6:29 AMKryptonite says:
Very nice, might just get my baseball bat out and get rid of my television, no, distraction. In style.
May 19, 2010. 12:08 AMbboydru says:
 For this part, did you use the same paint? Did you just carefully spray it on or do it by hand?
May 8, 2010. 2:53 PMtbcross says:
Wow I love this! I have tried to paint my kids old bikes over the years and never had much luck am gonna definitely give this a try we have 3 old ones that the kids got too big for will start on one of those (just in case my usual luck kicks in) Thanks a bunch!!
Apr 12, 2008. 7:31 PMcraftymamasguide says:
Very cool.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:Panda Face
