3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bike Phone v1.0
Bike Phone v1.0
Just because you are some bigshot executive, does not mean you drive in comfort to work everyday. For those that lead a hectic life and busy schedule without the luxury of topping up their phone battery via a car cigarette lighter, this should do the job using one of those old dynamo's from the front wheel of a bike.
Step 1What You need
What You need
1. bike (not shown) 2. The dynamo for the bike light 3. The light (not compulsory but adds functionality) 4. An old charger, or new. 5. A phone
Something to cut the wire with is usefull to.
14 comments
Oct 11, 2006. 1:59 PMmwarren_us says:
How well does the phone stay in the holder when the bike goes through a pot hole or over a curb? It appears that the phone might bounce out.
Jan 6, 2010. 2:15 AMsmurfvendetta says:
Hi Stephen.
Do you know where I can buy lets say 100 bike light dynamos??
Jul 13, 2007. 1:14 AMArmChairQB says:
Might want to do something to protect it from Rain , too?
Mar 14, 2008. 7:32 AMlillebror says:
This seems very dangerous, I'm a bit worried about that the dynamo outputs different voltages. I don't know how high it goes though, but wouldn't you have to bike around at one speed all the time to get the phone to charge? Perhaps it works anyway, how have your biking and test turned out?
Jan 24, 2008. 4:01 PMarapahochris says:
looks so simple I am going to rig it up this weekend!
Jan 17, 2007. 5:28 PMFat Bagel says:
Oct 11, 2006. 6:44 PMLeon Close says:
I thought these dynamos produced AC at voltage proportional to speed. I could be wrong but I'm quite sure that Lithium Ion batteries won't like this one bit.
Oct 12, 2006. 12:39 AMsofa0ne says:
dynamo = A generator, especially one for producing direct current.
( http://www.tfd.com/dynamo )
Most Li-ion batteries also include special circuitry to protect the battery from damage due to overcharging or undercharging. As a general rule...however voltage should be monitored as well...
I should also point everyone who is interested in this type of project to check out this link...
http://www.batteryuniversity.com/partone-12.htm
Oct 22, 2006. 9:00 AMstinch says:
Bicycle dynamos are incorrectly named and produce AC not DC.
http://en.wikipedia.org/wiki/Bicycle_lighting#Dynamo_Systems
A rectifier will solve that problem.
Not all similar devices are as tolerent as mobile phones. Mobile phones usually share a single mains adapter between a lot of models that often have different battery chemistries. Nokias for instance all share the same charger.
Similar devices such as mp3 players that are powered by a regulated supply might not fair so well.
Oct 12, 2006. 1:26 AMtrebuchet03 says:
I took apart one of my cell phone chargers that died... Nothing special, it just provided a somewhat stable voltage. I assumed that the charging bits are onboard the phone itself which makes sense to me, they'd only have to design one charging circuit and then provide a somewhat "clean" voltage. I say "clean" because when I took apart a car adapter-charger , my voltage signal oscillated. Those things make great drivers for Luxeons with a little modification :P
Oct 11, 2006. 11:51 AMjoez34 says:
Great Idea! I assume that the original charger output is equal to the dynamo output? What if you used a small battery to store the charge from the dynamo and then charged the cell phone from the battery. This way you don't interrupt the charging cycle when you stop the bike for short periods.
Oct 11, 2006. 2:00 PMPyrobrooks says:
I would look at the charger. It should tell what voltage your phone charges at. Then I would buy a voltage regulator that matches that voltage. Attach the dynamo to the regulator input and then the charger cable to the regulatoroutput. (see make magazine vol 7 pg 137)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Stephen B
