This is a simple bike rack constructed from 3/4" PVC pipe.
Step 1: Cut PVC parts to length
Parts List: All 3/4" Schedule 40 PVC
(2) Wheel Upright - 22 3/4"
(2) Wheel base - 12 1/2"
(4) Base - 7"
(5) Splices - 1 1/4"
(6) Elbows - 90 degree
(6) Tees
PVC Glue
Step 2: Assemble using PVC cement.
Step 3: Use the new bike rack instead of leaning the bike against the garage wall, tree, car, etc.
1-40 of 57Next »
idood says: Dec 27, 2007. 5:32 PM
Very nice. I took your design and the design of the other person who made the two bike holder, and came up with this:
All the details here.
Thanks for the inspiration.
Collingwoodcorey in reply to idoodJun 21, 2009. 9:22 AM
Check this person's bike rack for two.........Absolutely brilliant!!!!!
fightnut in reply to idoodDec 30, 2009. 7:35 PM
I like this design a lot. Only things I might do differently would be add little 4-5" legs so the wheel sits down IN the rack, and the tire is slightly off the ground. My thinking is that the wheel being surrounded/braced more might reduce the leaning/flexing that is happening with this one.
And I might go with 1" pvc to also help reduce flex.
Very nice though! Thumbs up,
myates7 says: Aug 21, 2011. 4:34 PM
Great design. We modified it into a 5-bike setup with additional upside down "Ts" in between each upright wheel holder for extra support. Thanks again.
imarunner2 (author) in reply to myates7Aug 21, 2011. 7:41 PM
Post a pic. Would love to see your 5 bike version.
imarunner2 (author) in reply to idoodAug 21, 2011. 7:44 PM
Very nice!
laughingcoyote says: Dec 12, 2012. 11:02 AM
The legs suggested for idood's 2-bike holder can be easily added by using 3-way corner fittings on the corners of the base instead of the usual two-way (90 degree) ones. As this would raise the rack up, you might want to use the slightly longer original dimensions for the wheel base and maybe the wheel upright, since it seems that a wider profile of the wheel would be in the rack. (Idood doesn't explain why he changed various dimensions in his design. The shorter base dimensions seem to push the bike wheel higher into the upright, which might make it more stable. But if you have a roadbike instead of a mountain, looking at idood's photo it might not fit. Legs probably would solve this problem, but then you would want to make sure that the base would be long enough. You will particularly want to check your dimensions if you add the longer legs suggested by fightnut.)
myates7 says: Aug 23, 2011. 7:10 PM
5-bike version. Thanks again.
AggieAshley99 in reply to myates7Jan 2, 2012. 7:14 PM
Love this bike rack! We have three boys and too many bikes -- they are like clothing one has outgrown but the next child will need. I need to store at least 5 and this is the best solution I've seen. How much did this cost to build? Thanks!
imarunner2 (author) in reply to myates7Aug 23, 2011. 8:16 PM
That is sweet!
fmassa1 says: Jul 31, 2011. 11:25 AM
Thanks! I made it today! http://farm7.static.flickr.com/6130/5994418461_4764c25689_m_d.jpg
dollardude says: Jun 27, 2009. 11:12 PM
great idea, you could also use not plumbing pipes but steel pipes if you wanted it alot stronger
fightnut in reply to dollardudeDec 30, 2009. 7:26 PM
The only problem with using steel pipes is the cost. You would be better off buying a metal stand like this,  it would be about the same cost.
Junkyard John says: May 14, 2006. 6:33 PM
Why not use a kickstand?
fightnut in reply to Junkyard JohnDec 30, 2009. 7:23 PM
They're added weight that stays on the bike all the time.
cjos9703 in reply to Junkyard JohnJan 31, 2008. 8:24 AM
Most bikes do not have kickstands. Great idea!
abadfart in reply to cjos9703Apr 21, 2009. 11:56 AM
my road bike didn't have one when i got it but i wot one at walmart along with a baby trailer
imthatguy1125 in reply to cjos9703Mar 6, 2009. 2:46 PM
actully mast cheper ones do
cjos9703 in reply to imthatguy1125Mar 7, 2009. 5:13 AM
The bikes we have do not have kickstands. We have 4 bikes by 3 different makers none have kickstands.
imthatguy1125 in reply to cjos9703Mar 7, 2009. 10:43 AM
i have 3 bikes by three different makers and they all do but they are not like racing bikes
cjos9703 in reply to imthatguy1125Mar 8, 2009. 2:25 PM
We have redline which ia a racing bike (BMX), specialized (a road racing bike and a cannondale. None of which has kick stands. I made two of these bike racks, they work really good and are cheap to make.
imthatguy1125 in reply to cjos9703Mar 8, 2009. 2:54 PM
ok
lilpepsikraker in reply to imthatguy1125Aug 7, 2009. 1:52 PM
Weird. I have never seen a bike without a kickstand. Where are you?
carpe_noctem in reply to lilpepsikrakerApr 15, 2010. 10:00 AM
kickstands are usually pretty hevy(by necessity)
people who are serious about the performance of their bike and want to cut weight, or just don't like the way it looks often remove them.
as for me, i just took mine off because it got in the way and wouldn't hold my bike up well anyway. Plus a combination of the above mentioned
PS ride fixies, cuz they're fun(not cu z they're trendy)
ShadowFacsimile in reply to Junkyard JohnMay 18, 2006. 3:44 PM
A kickstand by itself weighs more than a third of my racing bike's frame. Good idea for a frumpy cruiser, but not my gossamer baby.
sharlston says: Aug 8, 2009. 6:45 PM
cool ible im getting a bmx in a couple of days! :)
Krako says: May 26, 2009. 6:31 PM
Great thinking - I really like the modification to the original idea - this should do the trick for the rack that I need - it needs to be transportable & fairly lightweight. - Great design!! Thanks !
imthatguy1125 says: Mar 7, 2009. 10:45 AM
how stable is this
imarunner2 (author) in reply to imthatguy1125Mar 7, 2009. 3:47 PM
It's pretty stable. I think if I were to make any mods to make it more stable, I'd simply fill the base with concrete to make it heavier. But the base is wide enough and my bike is light enough that it has never tipped over on me.
jgodsey says: Jul 4, 2008. 2:30 PM
i wonder how i can mount that in my pick up truck?
imthatguy1125 in reply to jgodseyMar 6, 2009. 4:57 PM
use duct tape
badaboum says: May 10, 2006. 12:36 PM
You could make it a multi-bike rack by joining together other racks. Great invention!
ShadowFacsimile in reply to badaboumMay 18, 2006. 4:35 PM
That's what I did for my parents' cyclocross rigs-- just make two racks as imarunner2 described and replace two of the elbow feet with tees to attach them. Mom and Dad look adorable on their little red matching bikes, but the garage was becoming a cyclism disaster area.
imthatguy1125 in reply to ShadowFacsimileMar 6, 2009. 4:55 PM
i am gonna make one for three bikes
Amcain says: Aug 22, 2006. 10:20 AM
Make mine a double! A variation from the original to keep 2 bikes as close to the wall as possible (so my wife doesn’t hit them with her car) PDF drawing attached.
Tez23 in reply to AmcainNov 16, 2008. 7:30 AM
Do you have the dimensions for building the double?
SharkVol in reply to AmcainNov 8, 2008. 2:55 PM
I like your version. How can I get the PDF?
imarunner2 (author) in reply to AmcainAug 27, 2006. 6:13 PM
Very nice!
bigwhitebear18 says: Oct 3, 2008. 10:07 PM
Just made one of these for my apartment instead of leaning the bike against the wall and having it fall over in the middle of the night to scare the bejeezee's out of me. Very simple and cheap, cost me about $7 total. It is a little small for my mountain bike though. I have to squeeze the tire into the rack for stability. I might just make another with some longer splices and give this one to a friend. Great instructable.
bikingbrady says: Jul 27, 2008. 6:31 AM
These are GREAT instructions. I would agree with the adding of concrete to the bottom sections. Without it, my tandem would not stay upright in the rack. It worked perfect with concrete in the base however.
1-40 of 57Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
