The solid weight I can carry will surpass the safe use of conventional V-breaks and I had 5 pallets stacked on it only to get a small bounce going down the road. (Tire pressure is everything!)
This is not my own design. I rode pedal taxi for years in Phoenix. This trailer is made from a hand truck and is modeled after a 3 passenger taxi that came from San Diego.
This main photo is on a "test" run (for beer!) and taken by myself.
Remove these ads by
Signing UpStep 1: Get a hand truck.
I used a grinder with a cut off and grinding wheels, hack saw, tubing bender, drill, and a welder. Other than the hand truck you will need some 1/2" iron pipe, 5/8" iron rod stock, 1" flat washers, and various parts for the hitch. (in later steps)
1.I cut the welds off the center tube at the cross members and cut the tube itself at the handle where your hand goes.
2. At the bottom cross member cut the outer tube on both sides and you will have a large U with 2 cross members and some tube from the handle still attached.
3.Cut off the tongue of the dolly flush at the tire guards.
4.Use a tubing bender and bend the center tube to fit YOUR bike.(this picture is how I sized this trailer around the tires on MY bike (700c not 26"). Your situation will be and look different. The 1/2" iron pipe is used to size the distance to your hitch)
Visit Our Store »
Go Pro Today »
kids electric buggy wheels with a 27 litre plastic storage box and the other trailer was made from the bottom of a pram with slightly large spoked wheels.
After a problem with the hitch i added 2 heels and both trailers have 4 wheels and have worked without fault since then in wet or dry conditions. Have also posted an article on a site called biketrailerblkog.com site - look for user: Neil1801. If you have not heard of this site it may be of some interest to you as well.
Thanks for the link. there is some great stuff there. Can you send me a link to what you made or even post a photo here....or here:
http://www.instructables.com/community/Post-your-bikes/
how are the wheel bearings holding up?
Giving the fact that I have had this hand truck for years, I put out less than $50 for this hearty trailer.
Thanks
The area I live in has lots of horse property. People seem to have plenty of them. I purchased this particular bottom half for $5.
