Remove these ads by
Signing UpStep 1Collect Tools
Hammer
Chisel
Hack saw
Adjustable wrench (two)
Ratchet with 5/16 socket
Pliers
Drill with phillips bit
Tape measure
Sharpie
Combination square
If you have a circular saw, it may be easier than using the hammer and chisel. Eventually I got sick of using the hack saw and borrowed a friend's angle grinder with a cutting disk.
I wonder if this can be put into a box and marketed . . . . . .
Nice idea and thanks for sharing
this is beautifull, rabid_engineer said it perfectly, "in it's neatness visually appealing"
I really wish I hadn't sold my bike, if I still had it I would go out and do this!
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_1030_1030
I agree with the posts regarding the "swivel-ability" of your attachment point. I've designed and built a number of bike trailers over the years, and have accomplished that "swivel-ability" by moving the attachment point for the trailer to just behind the rear wheel/tire of the bicycle using 3/4 X 3/4 square steel tubing that is also available from hardware stores and then using a second caster to allow the full range of trailer tongue motion: up and down, side to side, and rotational.
Though the current trailer I designed makes use of a push/pull golf cart that I purchased off CraigsList for the low price of $5 and a plastic tub, the trailer attachment design I suggest has held up very well all this summer over some very extended bicycle rides (one over 225 miles).
I also replaced the cheap bearingless wheels that came on the golf cart with sleeve-bearing wheels that I bought from Northern Tools - a great place to shop for wheels for projects like these.
You can see the trailer coupler I describe also posted on Instructables at http://www.instructables.com/id/Building-a-strong-flexible-bicycle-trailer-coupler/
