Step 4Assemble the Axle
Cut the 1x3 to about 26 inches long and position in the middle of the chassis frame. There should be about a 1 inch overhang on each side.
Bolt the 1x3 to the frame with a 1 1/2 inch long 5/16 hex bolt. I used a cut washer and a nut with nylon insert, since this is a crucial connection. You'll have to counter sink the hex head so that it doesn't interfere with the axle.
Before attaching the axle, spin a 1/2 inch nut onto the threaded rod first, then two nylon washers (bushings). Spin two more nuts onto the threaded rod and position next to the conduit straps as shown.
Pre-drill through the wood and angle iron and bolt the conduit straps onto the chassis frame.
Add Comment
