I used to keep them in the living room, behind the sofa. The problem with that is they take up too much room, and are easy to accidentally knock over.
This is where the bike tree comes in. An easy (to make and use) bike stand that stores the bikes vertically to take up less room. Plus it's completely free standing - you don't need to make any holes in the wall or ceiling, and can be moved at any time (though I'd take the bikes off it first and remove the ballast). :)
Remove these ads by
Signing UpStep 1Parts
I bought all the following from a UK DIY superstore called B&Q for under 35GBP.
2x square wood decking
1x 1.8m fence post
1x bolt down fence post support
2x bike hooks (bought from Halfords)
2x stone coping (ballast)
bag of bolts for the post support
bag of screws for the decking
2x bags of sticky back felt (to use as feet)
Tools:
1x electric drill and wood drill bits
good screwdriver that fits the screws you have bought
spanners or socket set for the bolts
When looking at your photos, your decking looked a lot like a pallet. I searched around the store and asked if they sold pallets, but apparently they don't. They will however, give you a pallet with a $15 deposit. I then picked out two 2"x4"x8' boards and metal support for about $6. I would have gone for a 4"x4"x8" fence post, but those were going for almost $19. I found a couple of rubber coated utility hooks for just over $5 and two boxes of screws for $4.
I began by cutting 1/3 of the "Quickcrete" pallet off. I screwed the two 2"x4"s together and then cut two feet off it. I mounted the newly made 4"x4" to the pallet and used one of the leftover pieces of 2"x4" as a support after cutting two 45 degree angles off. I drilled a couple of guide holes and manually drove the utility hooks into the post and it was good to go.
The nice part about using a pallet was that the wheel fit snugly into the grooves between the boards, eliminating the guide boards as well as the back board.
Superb idea and again, thank you! For under thirty bucks and a couple of hours, I have some much needed free space.
Oh and I just noticed dclays comment below. All great ideas! Keep up the good work!
