3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bike generator for Tufts Kid's Day Fair 2008
Bike generator for Tufts Kid\
I'm a member of engineer's without borders at Tufts, and as part of a community outreach initiative we decided to build a bike generator for Tufts yearly Kid's Day Fair.
It was excellent demonstration of energy efficiency. The kids could either power a compact fluorescent light or a set of incandescent light bulbs. The incandescent bulbs are on the handlebars and are not completely visible in the pictures I have. :-(
The generator was a 12V dc motor from Grainger. link
The incadescent lights were automobile headlight light bulbs. The compact fluorescent was a 12 V DC model typically used for RV's.
A big old capacitor (1 F) was also wired in to help regulate the voltage.
Message me if you have any questions.
Big thanks to everyone on instructables that gave me advice in making this project!
13 comments
Dec 14, 2010. 10:44 PMgreatboss says:
very good,i like it .it is better to put on more details .
Nov 16, 2008. 10:17 PMphilipster says:
hey for the dc motor could you use say a generator out of a car and would it produce more energy?
Nov 3, 2010. 5:52 PMbgrasmeder says:
I helped work on a bicycle powered guitar amplifier and we used a car alternator. The big snag was that alternators require electric flow INTO them before they will produce anything out, so we used a battery that fed in. You also have to have a switch to engage the device only once you've got enough rotations per minute on your bike wheel. Think about your car and how it stalls below a certain RPM. You have to get it up and keep it up above that threshold RPM before you engage the system.
(http://www.gypsycarnivaltour.org/)
May 28, 2009. 8:29 PMmagganrchy says:
I had this same question and someone answered it for me so here goes. Alternators in cars have a magnet and a copper coil just like any other generator...but the magnetic isn't permanent. It takes a little bit to generate the electricity needed to turn the magnet INTO a magnet powerful enough to generate a measurable amount of electricity. (there is a small residual charge that generates the energy at the start) if you replace the magnet with Rare earth magnets then it will work just fine...or you can just pedal really hard at the start.
Apr 4, 2009. 10:15 AMluigi2999 says:
The reason why you couldn't get it to work, is because you have to get the alternator up to speed, then u have to energise the fields of it to make it start to produce electricity, then, once you energised them, it should work fine.
Apr 4, 2009. 5:08 PMluigi2999 says:
U mean a load? The alternator is a voltage source, and light bulbs are a load. There may be no negative terminal, the alternator casing itself may be negative, while there may be only one pin for a positive terminal. So, you may want to solder a wire to the case, and hook up a wire to the terminal, and test the output voltage with a voltmeter.
This guy shows his set-up of a car alternator and bike, check out this vid.
http://www.youtube.com/watch?v=R_-wVuEkk2E
Nov 17, 2008. 1:00 PMlordploppy says:
Hola! Complete amateur here... we are thinking of putting something together that will power a television. What are our chances of generating enough power to do that?
Dec 16, 2008. 10:53 PMomnibot says:
May I suggest a large stepper-motor? These can be used as very effective AC-generators but you will have to ad rectifiers. Google for "stepper motor generator".
Nov 8, 2008. 2:15 PMwingsinger says:
Nice bike generator! The Grainger link no longer works,do you have the part number for the DC motor you used? What kind of Wattage output are you getting?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:musing mumbler
