This bike trailer is made of wood but has a metal frame. It can fit many different bikes and works well.
It is quite easy to make and not too expensive, it didn't take me that long and can carry quite a lot of stuff.
Hope you like it.
Don't forget to vote for me in the wheels challenge if you do!!!!!
jakobus9 says: May 17, 2012. 6:12 AM
it's not an instructable though.
but I assume it was already built when you posted it.
I want to make something like this. your attachment method is pretty clever. but how is it connected to the rear axle?
lime3D in reply to jakobus9Jun 4, 2012. 11:03 AM
Agreed, this isn't really an instructable. Please consider revising.
Alex Loftie (author) in reply to jakobus9May 17, 2012. 11:05 AM
I used a right angled piece of metal which i drilled two hols in one on each section as seen in the drawing. I then attached this to the bike using the bold which holds the wheel to the bike. After that I used a ball joint ( to allow it to turn when i go around a corner), this was bolted through the second hole. Using a piece of metal bar which i had put a screw thread on I joined together the ball joint and a metal tube which then went to the body of the trailer as seen in the drawing.
Hope this helps you if not tell me and I will try to get a picture of it for you.
IMG00126-20120517-1849.jpgIMG00127-20120517-1850.jpgBall-Joint-Rod-End.jpgIMG00124-20120517-1849.jpgIMG00125-20120517-1849.jpg
AussieAnglerGal says: May 26, 2012. 10:55 AM
wow brilliant :D
might have to make one of these so i can ride my bike AND carry fishing gear to get to the further-away fishing spots
Alex Loftie (author) in reply to AussieAnglerGalJun 1, 2012. 6:02 AM
Thanks, sounds like a good idea.
Aron313 says: May 19, 2012. 9:36 AM
Now put a electric motor in it that will push you.
Alex Loftie (author) in reply to Aron313May 19, 2012. 10:22 AM
That's a good idea but I don't think it would push me very well as the link between the bike and the trailer can pivot.
But you never know.
Aron313 in reply to Alex LoftieMay 24, 2012. 4:54 PM
A guy that works with me at a bike shop has one. Its awesome. The pivot is exactly like the one he has. Good luck!
Alex Loftie (author) in reply to Aron313May 25, 2012. 2:51 AM
Ok i will look into it but I don't think I have enough money to buy a motor.
Aron313 in reply to Alex LoftieMay 25, 2012. 3:07 PM
I recommend finding a scrap one from some kind of machine.
Marcus Worsley says: May 17, 2012. 10:54 AM
why is jon there?
Alex Loftie (author) in reply to Marcus WorsleyMay 17, 2012. 3:33 PM
It was when he came to mine last winter hols
rimar2000 says: May 17, 2012. 2:54 PM
Nice work!
I am thinking to make one of these for me. Thanks for sharing.
Alex Loftie (author) in reply to rimar2000May 17, 2012. 3:24 PM
Your welcome and thanks for the comment.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
