Bill Cipher Pyramid Speaker
551
7
Posted
Introduction: Bill Cipher Pyramid Speaker
This project is inspired by the pyramid design for Bill Cipher from the show Gravity Falls and was created for Design Technology Class. Currently the product is unfinished and this serves as a production plan. The page will be updated when the product is finished.
Materials:
  1. 6x 297 x 420 x 3 mm clear acrylic
  2. Visaton FR7 speaker
  3. Solvent based acrylic glue
  4. Philips RGB light strips
  5. Acrylic enamel black spraypaint
  6. 4x 4mm nuts
  7. 4x 4mm bolts
  8. 12x washers
  9. Electrical tape
  10. Speaker amplification PCB (+components)
  11. 3.5mm audio cable
Step 1: Laser-cut the Pyramid Layers
Using the 2D CAD pyramid file I made, laser cut the sheets of acrylic into the pyramid sheets, bases, spacers and mounts.
Acrylic pieces produced:
  • 30x pyramid sheets
  • 2x pyramid layer tops
  • 3x pyramid layer bottoms
  • 1x speaker mounting sheet
  • 16x pyramid spacers
Step 2: Glue the Layers Together
  1. Glue the sheets together, remembering to replace the extra pyramid sheets with the bottom sheets.
  2. Don't glue the bottom on for the top layer.
  3. Don't glue the top pieces of each layer on so you can access the interior
Step 3: Drill Mounting Holes for Speaker and Wire Pass-through Holes
  1. Using the speaker mounting sheet (the one with a hole in the middle) and the speaker to determine where to drill the holes and what size to drill them. Be sure to make them slightly larger than the mounting holes on the speaker to ensure you get a good fit.
  2. Drill a large hole next to the largest hole but still near the center of the sheet for wire pass through
  3. Drill wire pass through holes in the center of all the top and bottom sheets.
Step 4: Install Speaker
  1. Place washers on each of the four bolts and slide them through the holes drilled in the speaker mounting sheet earlier.
  2. Place two washers on each bolt
  3. Install the speaker on the bolts
  4. Secure the speaker in place by screwing on the nuts
Step 5: Solder the PCB
  1. Collect the necessary components and solder them careful to the PCB using the amplification circuit sheet as a guide
  2. Test that the circuit works by plugging power in and attaching (temporarily) to the speaker
Step 6: Assemble the Base
  1. Cut slots in the side of the base pyramid to accommodate the audio-in jack and the switch.
  2. Cut slots in the back of the base pyramid to accommodate power in for the RGB LED strips and the speaker itself
  3. Cut a slot in the front for the remote receiver for the RGB LED strips
  4. Cut four lengths of RGB LED strips to form a square on the bottom with space in the middle for the PCB and RGB LED controller
  5. Solder the PCB to the speaker unit
  6. Use double sided tape to secure the PCB and RGB LED controller
  7. Solder the four strips to each other, leaving the last strip detached, outside the housing to avoid damage
  8. Using the remaining solder points on the strip, solder pieces of wire long enough to supply power to the RGB LED strips that will be installed on the next layer. Having slack is not a problem, in fact it's ideal if you do.
  9. Stick the LED strips to the base
  10. Feed the power cables through the cutout you made
  11. Feed the cable through its cutout
  12. Glue the remote receiver and switch into their respective cutouts
  13. Plug the RGB LED controller into the strips
  14. Feed the RGB LED cables through the pass through hole
  15. Glue on the top sheet of the bottom layer.
Step 7: Install the RGB LED Strips
  1. Cut four lengths of RGB LED strips to make a square for the middle and top layers.
  2. Repeat step 7 (from the last section) for both the middle and top layers
  3. Repeat step 8 (from the last section) for the middle layer
  4. Repeat step 9 (from the last section) for both layers
Step 8: Attach Layers and Prepare for Painting
  1. Glue all the spacers together in groups of two
  2. Glue the pairs onto the top of the base layer so they make a square with a side length of roughly 15cm
  3. Tape the pass through hole so just the wires can get through. This is to ensure paint doesn't get into the interior
  4. Pass the wires through the middle layer
  5. Solder those wires onto the RGB LED strips in the middle layer.
  6. Glue the middle layer onto the spacers.
  7. Pass the wires in the middle layer through the top sheet and glue the sheet on.
  8. Attach the final layer by feeding the wires through the last bottom sheet.
  9. Solder the wires to the RGB LED strips
  10. Glue the final bottom sheet to the top of the pyramid (top layer)
  11. Make sure to use the electrical tape to seal off the openings.
  12. The structure and electronics are all finished.
Step 9: Painting and Cosmetics
  1. Print the hat in black 3D print filament
  2. Mask off the speaker by wrapping masking tape around the spacers so you form a sort of vertical tube of tape in between the bottom and middle layers.
  3. Mask off the eye for Bill cipher using the reference sketch as well as the bow tie
  4. Spray the pyramid with a coat of the paint and continue adding coats until the finish is to your satisfaction.
  5. Once the paint is dry, remove the masking tape and test all the electronics
  6. Glue the hat onto the top of the pyramid
  7. Sketch the bricks onto the pyramid with a pencil
  8. Use a rotary tool to cut out the mortar, exposing the clear acrylic so light can shine through.
  • Remote Control Contest 2017
  • Arduino Contest 2017
  • LED Contest 2017
    LED Contest 2017
Questions & Answers
