3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Binary Marble Clock
Step 2Preparing the base
Preparing the base
I took a a piece of wood( 3x2 cm , 50 cm long) that I found in a closet and used that as a base for the clock.
I started by drilling eleven 5 mm holes straight through for the leds. On the top I then used a 12 mm drill and drilled down like 7 mm at each 5 mm hole to get an indentation for the marbles to be put into. On the bottom I used an even wider drill and drilled out a huge chunk of wood over each led hole and then I chiseled a trench between the holes so the cables can be put there.
In the middle between the hour- and minute-leds I drilled and chiseled out a huge crater to put the electronics into.
After sanding it a bit and painted it all with a dark brown color.
1 comment
Oct 8, 2009. 4:10 AMaliasjanedoe says:
Why do you have 5 hour lights instead of 4?  Are you doing military time, 24 hours rather than 12?
Very nice clock, BTW.  I want to do something similar as a watch, but I can't find the chip already programmed for a reasonable price, and I don't want to invest in the equipment to do it myself for a single project.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:matseng
Swedish expat living now living in Malaysia after spending some years working in Dubai.
