Take some small leafs and use water to stick them to the eggs. This will hold the leafs in place while you insert the eggs into the pantyhose. Be sure...
Peel off some red onions. If you can't find red onions then the brown ones ar also ok. I used red because I wanted a more intense colour. You could a...
Remove the eggs from the pantyhose and clean them. You must do this before the eggs are cold because some leafs during the boiling process, dries out ...
Use some bacon fat to give the eggs a shiny look. After you've done this they will be a little greasy and shiny but don't worry, after they sit for a ...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
