Biodegradable Fishing Lures
19,631
210
23
Posted
Introduction: Biodegradable Fishing Lures
Green Design Contest
Runner Up in the
So the big question is, why even do this?
Well it is rather simple: we all snag gear, tie a bad knot or simply put lose our lures at one point or another. While we can't always retrieve our broken gear it only makes sense to try to limit the impact of the lost equipment. Whether its a bird or a fish, the plastic most lures are made of cannot be digested and can kill or harm the animal that consumes them.
So here is my solution, make a recipe for a lure that anyone can make at home with ingredients anyone can pick up at a local store.
Lets begin!
Step 1: Ingredients
So its a simple recipe:
-4 packets of gelatin
-3/4 cup of water
optional (but highly suggested)
-food coloring
-3 fish oil pills
Step 2: Making the Mix
Start by pouring 3/4 cup water into a small pot.
If you choose to use fish oil pills take a pin and insert it into one end. Remove it and squeeze the oil out of the capsule into the pot.
Mix in the 4 packets of gelatin.
Step 3: Mixing It All Together
Now put the pot on the burner and turn the heat to low. Mix the ingredients together while it is heated until it reaches a a consistency similar to water. At this point add in the dye.
The gelatin should only need to be on the burner for 2 minutes to get to this point.
Step 4: Pouring the Lures
Now it is time to pour the molds. There really isn't much to say here. Simply spoon the mixture into your mold, chill in the freezer for roughly 15 minutes and then taken out of the mold and repeat the process.
Step 5: Need a Mold? Make One
Don't have a mold? No problem. We can make you one really easy! Simply take a handful of straws and cut them in half. Rubber band them together and insert them vertically into a container. Pour in the solution and let them chill in the freezer.
The gelatin will take significantly longer to set since there is a higher volume.
Step 6: The Final Solution
After the gelatin has set the lures can be taken out of the molds. I like to wrap the lures in paper towel and chill in the fridge until I use them.
The final solutions can be as complicated or as simple as you want.
The 'straw mold' can make worms and grubs, while bought or made molds can make anything imagined.
Step 7: Final Assessment
I'm not going to claim that this is a perfect substitute for conventional rubber lures.
Pros
-Environmentally friendly
-Fairly inexpensive
-Scented so it can work as a bait or a lure
-Makes a large quantity per batch
-Bluegill seem to like it in my test lake
Cons
-Realistically only good for one cast per lure
-Hard to hook with out splitting the gelatin (though this can be fixed by setting the hooks in the mold when the solution is initially poured)
-The lure must be chilled until it is used or it will become too soft to be useful
-Require delicate handling
-If a fish hits the end of the lure it can rip off the back of the lure (this can be minimized by rigging the worms with a hook in the front and hook in the back)
Final Assessment
While this recipe does have its issues, it is a good start to eco-friendly lures being a possibility for anyone. I will be the first to admit that this recipe does have plenty of room for improvement in durability. But the concept still stands, a lure that is made from biodegradable ingredients that can be made by anybody with access to a kitchen and has the capability to catch fish.
  • Thanks, here is a li...-JohnP50
    JohnP50 made it!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
22 Comments
make a mold out of clay...that solves that..let the clay harden..pour the mixture in,,stick in fridge..all done
the fish in my local lakes dont seem to like soft lures, but ima try this anyway.
Efiicient, but I'd tamper with it a bit if I did it myself. Like others said, and some starch to make it less erodable.
What do you mean by solution when making a mold
very good idea and i have suggestion - why not using something fiber to make it more standing!like some string or something else ...
I don't see what a handful of straws will get to. If I fill them, I'll end up with a handful of worms; otherwise, I get a large gel lump with a hole in it. Can you explain what the mold is? TIA
Nice, please check out my guide on bass fishing.
This is truly inspiring! I want to make some! Thanks for posting!
Good job! I'm going to make a few for when I go fishing!
really like this idea, and keen to see how things go with an improvement in the recipe. Will have a play myself when I get time
