Raspberry Pi "Pie Case"
Introduction: Raspberry Pi "Pie Case"
My old laser-cut Pi case broke so I decided to make my own one out of salt dough which protects the Pi, costs almost nothing and is biodegradable. WARNING: You will probably SPEW if you eat this pie!
Step 1: What You Will Need.
To make this you will need:
1/2 cup Plain flour. Do NOT use self-raising flour.
plastic wrap
1/2 cup water
1/2 cup salt
ramakin about the size of the raspberry pi
mixing bowl
Step 2: Mixing
Add the flour, salt and water in and start mixing. Keep mixing and kneading until the dough is not powdery or wet, but stretchy and has no lumps. If it becomes very crumbly add more water or add more flower if it is too wet.
Step 3: Making the Lid of the Pie
Split the dough in 1/2 and flatten one piece out. Then place the ramekin on top and cut out a circle about an inch bigger than the ramekin.
Step 4: Making the Base of the Pie
Flatten out your dough with a rolling pin but make sure its not too thin or else it will fall apart. Now pick up your dough and place it on the upside down ramekin. Cut around the edges so you have only the base of the pie.
Step 5: Cutting Out the Holes
Wrap your Raspberry Pi in plastic wrap to protect it from getting muck on it and then place it upside down on the base of the pie. Cut holes approximately where the plugs go in.
Step 6: Baking
Slide the lid and base of the pie on to a baking tray lined with baking paper. Place it in the oven at 180 degrees Celsius (365 degrees Fahrenheit) and keep baking until hard. WARNING: Do not put your raspberry pi in the oven.
Step 7: Finish!
Take the pie out of the oven and using a knife remove the pie from the ramekin. Place the Pi inside the pie and connect the cables through the holes and place the lid on top. I drew pictures on the top with pens. If the holes are too small make them bigger using a sharp knife.
You now have yourself a Raspberry Pi "Pie Case".
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Oh no, I Ieft my RasPi inside the pie case and now the solder has all reflowed, help help! :)
    oh no. Did you leave your Pi in the case while it was baking.
    ... that would be it. There should be a warning or something ;)
    Hmmm. Do you have any idea why that happened.
    I installed heatsinks on my raspi.
    There's a warning on step 6......
