Introduction: Biodegradable Toilet Paper Roll Seedling Pots
With these easy to make biodegradable pots there's no need to go out and buy expensive peat pots. These are the perfect size for normal size seedlings. Big seeds like sunflower seeds are not suitable for a starter pot this size but that should be a given. This pot is perfect for starting seeds and can be planted directly into a bigger container or into ground soil. They cost almost nothing and are a great way to re-use something you would have thrown away anyway.
Step 1: Fold the Roll Into a Square.
Fold the roll in half one way. Then, fold it in half the other way, making sure the creases from the last fold line up and you have a square!
Step 2: Cut the Roll in Half.
Cut the roll into two parts.
Step 3: Cut Out the Flaps.
Fold the roll in half one way and make a 3/4 inch cut, then fold the roll in half the other way and make another 3/4 inch cut. You should have 4 cuts in total on the bottom of your roll. Repeat this step on the other roll.
Step 4: Crease the Flaps.
Fold and unfold all of your flaps. This is to establish a flat, even, square bottom of the pot.Repeat this step on the other roll.
Step 5: Fold the Flaps Cardboard Box Style.
Fold the first three flaps down, overlapping each other. Fold the bottom flap down first, then fold the left flap down, overlapping the bottom flap, then fold the top flap down, overlapping the left flap. Now here's the tricky part. Fold the right flap under the bottom flap and over the top flap. This holds the pot together. Repeat this step on the other pot.
Step 6: Plant!
You're now done with your two biodegradable pots and can add potting soil and sow your seeds. You can even make an army of pots like I did. Thank you for reading my instructable and don't forget to comment. This is my first instructable and I would love to hear your feedback!
