3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Biohazard beer barrel
A cheap and easy cooler that belches fog into your party.
Any mention of this project must provide a link to www.zieak.com with credit to Ryan McFarland.
Step 1Collect materials
Collect materials
For this project you will need:
*55 gallon metal drum (try industrial sites or the local landfill for a free one)
*32 gallon plastic garbage can
*square
*marker
*circular saw with metal cutting blade or a hand saw
*hearing and eye protection
*metal file
*biohazard sticker or magnet (cheap ones at labsafety.com) or paint and a steady hand
*fog machine
*duct tape
*ice
If you don't want to cut the metal you can easily use a hand saw and cut the handles off of the garbage can. I wanted to keep the handles on my garbage can and have access to more barrels so opted to cut the barrel. Put the garbage can on top of the drum. If you plan on having the drum against a wall or in a corner offset the garbage can so that the gap between their rims will allow the fog out toward your guests. Mark where the cuts will have to be made with a marker.
22 comments
Nov 2, 2006. 4:01 PMimpulse94 says:
Perhaps use dry ice if you don't have a fog machine?
I'd also recommend not to use a real biohazard container! ;-)
Jul 12, 2007. 9:41 AMEllsinc says:
You could but theres probably a chance that the temperature would crack the bottles.
Sep 2, 2007. 4:04 PMaphyllophorales says:
if the dry ice is in water, and separated from physical contact with the bottles, the bottles would be safe, but it would still be a trade off. - dry ice will eventually ice over without water circulation and become ineffective - dry ice fog production relates directly to water temperature, so one would have to test whether a desirable fog production to water temperature level can be established and maintained + dry ice fog is completely hypoallergenic, which, i can assure you, is not truly the case for any sources of fog other than LN2 or dry ice. that's why professional theater uses dry ice or LN2 about 98% of the time, and, due to the risks of LN2, thats probably 90% dry ice. LN2 (liquid nitrogen, FYI) is a second option, but the risks in handling LN2 almost never outweighs the benefits of its use. If it splashes on your clothes, youre fucked.
Oct 29, 2009. 7:03 PMbennyboy13 says:
Whats the prob with LN2 getting on your clothes???? I have been working with it for years and never had a problem, It must be used with respect and sensibility but its not acid :) I have been working with it long enough to know the burn time and even able to put my hand in a vessel full of liquid nitrogen and come off unscathed ( about 1/2 a second) as long as it doesnt get caught in any crevices LN2 runs off you it doesnt "stick"
Apr 18, 2010. 12:49 PMM4industries says:
 Yeah, it has the lowest surface tension I have ever seen.
Oct 31, 2009. 12:54 AMWarlrosity says:
Yet another wonderfully disturbing piece.
Oct 29, 2009. 6:07 PMlifelong-newbie says:
That's a really sweet looking barrel. I'm thinking about making one for halloween
Oct 31, 2008. 6:53 AMDark Solar says:
MMMMMM....Newcastle Brown Ale...Lrrgrglrlglrgglrlrrrglg
Sep 24, 2008. 3:51 PMparsephoni says:
I am so doing this for my Halloween party this year! I love it!
Jun 21, 2008. 12:25 PMEsmagamus says:
Find some green glop that glows in the dark or under blacklight!
Oct 15, 2007. 6:19 PMrheide says:
I know you mentioned getting the magnet at Lab Safety Supply store but I can't find it there. Any possible way to make a direct link? Awesome work by the way.
Sep 8, 2007. 9:21 PMYerboogieman says:
where do you but the fog machine? just stick it in then put ice on top?
Jan 16, 2007. 3:56 PMlemonie says:
You could also paint it "military" and have include an 'in case of emergency' (zombies) phone number...
Dec 30, 2006. 9:41 AMzv_odd says:
Insted of using a Biohazard sign, just whip up a stencil and spray it on, it looks cooler, plus you can stencil one of those biohazard symbols too. As theRIAA suggested Green LEDs at the bottem shining up through the ice, now that would kick ass.
Nov 8, 2006. 12:07 PMandresm says:
amazing!! GOOD JOB ZIEAK
Nov 4, 2006. 9:40 AMColumbusGEEK says:
Damnit i really want to make that one.
Nov 2, 2006. 12:38 PMmeddler says:
yeah, with like a tentacle coming out of the top and drooping over the side.
Nov 2, 2006. 8:43 AMtheRIAA says:
A-wsome. it needs green lights in the bottom of the ice
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:zieak(Zieak's site)
I like making things out of items that would have otherwise been discarded. Check out my other projects! Now a PE teacher in Mongolia! I don't have much time or even the resources to make much any m...
more »
