Biohazard/Radiation - Halloween Costume
  • last photo ←
My 2007 Halloween Costume. I didn't document the build process enough for an instructable but I did take lots of pictures after it was done.
The Geiger counter, which I found while browsing The Electronic Goldmine inspired the costume. I started with the Geiger Counter which (as disclosed by EG) was broke to begin with. I added blue LEDs on the gauge in place of the needle and used a sound-to-light module to activate the LEDs when the sound from a record/playback module played a looped Geiger counter noise through a speaker.
I bought the gas mask from eBay ($9 I think) and wired in a green LED light bar from SparkFun to light my face. Also, a mic was wired inside the gas mask which ran to a voice changing module. The voice module was wired to a speaker that was attached to the outside of the suit, with it I could change the pitch of my voice from very deep to very high and robot style.
I used washer drain hose and attached it to one filter port of the gas mask to run the wires for the LED bar and the mic in to the control box. An additional hose was attached to the mask and then to a fan box to blow fresh air into the mask.
The Geiger counter was powered with 4 AA batteries for the record/playback module and a 9v battery for the LEDs. The mask LED bar and voice changer were powered by two 9v batteries (wired parallel - I was paranoid about the batteries dying). The suit fans and the fan light bars were powered by 12v sealed lead acid batteries (I used two wired in parallel - again paranoid about battery time, this was overkill). The sealed lead acid batteries were carried in a backpack that I wore inside the suit, the fan boxes and the speaker were velcroed to straps of the backpack to help support them.
There were two fans for the suit, one blew air into the mask via a hose and the other blew air directly into the suit. An unintended but welcome consequence of the fan blowing into the suit was that it inflated it adding a comic effect to the whole thing. I was somewhat surprised at first since it's only an 80mm case fan but it's a Panaflo high speed so it does move quite a bit of air. I can't stress enough that ventilation was very important, this was a real Level B chem suit, it's like being in a human size Ziploc - without the fans I would have passed out. In reality a suit like this would be used with a SCBA (self contained breathing apparatus) but since those are probably like a billion dollars I opted for the fans. All in all it worked out pretty well, it was hot and I sweet like a pig but I was able to stay in it as long as I needed to - then went home and took a shower.
Supply list:
Geiger counter - The Electronic Goldmine (I can't find them here anymore but you can find them on eBay)
Gas mask - [href="http://search.ebay.com/gas-mask_W0QQ_trksidZm37QQcatrefZC6QQfromZR10QQfsooZ1QQfsopZ1QQftrtZ1QQftrvZ1QQpqryZgasQ20maskrQQsabfmtsZ1QQsacatZQ2d1QQsaobfmtsZinsifQQsaprchiZQQsaprcloZQQsofocusZbs eBay]
Level B chem suit - Spill 911 (cheapest I could find)
Blue LEDs and Light bars - SparkFun
Voice changing module, sound-to-light module and record/playback module - Electronics123.com
SLA Batterys, wire, switches, project boxes and other miscellaneous items - All Electronics
Can also be seen here
njnvgvatvafcvengvba.pbz
20 comments
Aug 22, 2009. 6:12 PMcomputek272 says:
You could have also used a Training Suit. It looks the same, is way cheaper but does not protect you from anything, since it's only for training. Why would you need it to in this case anyway?
Mar 20, 2010. 4:14 PMdtoma says:
Wow your right thanks for the tip.  I found one for 23 monies, http://www.edarley.com/finditem/25425#tabpos
Apr 24, 2009. 2:53 PMArticas says:
cool but it looks bulky but still cool
Oct 5, 2008. 7:02 PMzace123 says:
I found a cheaper suit
Oct 6, 2008. 7:33 PMzace123 says:
is not exactly like it but it does nice
http://www.northernsafety.com
135-3283
Oct 6, 2008. 7:38 PMzace123 says:
they also have some great boot covers look around the site you will most likely find something useful
Sep 27, 2008. 10:07 PMRenagade says:
very nice costume! question what voice changing module did you use? plan on using one for one of my costumes _
Sep 28, 2008. 12:22 PMRenagade says:
THANX! i'll try and use it! btw know anywhere where they sell it cheaper by any chance :P?
Aug 25, 2008. 5:56 PMbounty1012 says:
reminds me of the guy from timesplitters when you select him he sneezes inside the the suit and gets scared.
Mar 19, 2008. 9:15 PMEnigmaMax says:
it kinda looks like a hazmat suit for fat people
Dec 2, 2007. 11:22 AM!Andrew_Modder! says:
Tho's biohazard radiation suited up ppl scare me :-X, lol idk why it just is weird :-P
Dec 3, 2007. 12:36 PM!Andrew_Modder! says:
LOL ya :-) scaring kids :-D..
Dec 2, 2007. 9:05 PMa grain of alt. says:
Very cool. Looks like you put a lot of time and thought into it- hope ya won a costume contest or something with it!
Dec 2, 2007. 4:47 PMGorillazMiko says:
ha, pretty cool.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:mada
