Introduction: Bioshock Elizabth Choker
The bird it is..
Step 1: References
First things first: get some good images to help you get everything right!
Step 2: The Ribbon
You'll need:
- a blue-greyish leather or other piece of fabic about 3-3.5cm high and long enough to fit around your neck.
- white bias tape (2x lenght of your blue fabric)
- white fabric marker to create the pattern (mine was actually a 3d contur effect maker <3)
Step 1:
Glue the white bias tape onto the back side of your colored fabric. Be sure to let it overlap a bit so you can see the white thin stripe from the front (pic4).
Step 2:
Let's paint!
I recreated the pattern from the original design and will use this as help.
*If you would like to have the pattern feel free to ask me
Step 3:
I clipped a jewelry piece (pic7/8) onto each short end of the choker ribbon by using a pair of tongs and to have smooth edges and be able to close everthing later on(pic9).
you should be able to get these pieces from ebay or you jewelry and beads shop.
Step 3: The Brooche
to do the brooche of the choker I created a 3d model of it and printed it (via shapeways.com)
I am offering this printed brooche part for sale - 13€+shipping!
Besides, you'll need:
- a pin
- a print out of either the bird or the cage
- glue
- silver/metallic permanent marker
- a glas cabochon/gem stone 30x40mm
Step 1:
painted the brooche with silver permanent marker,twice.pic3
Step 2:
glued the print out into the dried brooche and used some simple crafting transparent glue to coat it 3-4 times. pic5
Step 3:
using jewelr transparent glue to fix the glas gem into the piece and secure it.pic6
Step 4: Ribbon+brooche
I superglued the jewelry pin onto the back of the brooche to be able to attache it to the chokers fabric
Step 5: Finished Choker of Elziabeth From Bioshock Infinite
There you go! The choker is done! :3
Cosplay photos will follow soon...hopefully :D
For more cosplay and WIP related stuff check out my other instructables ot visit me on facebook via Kion Cosplay .
You can also find me on etsy
Have fun creating stuff!
Step 6: Commission Open
Elizabth Comstock/Anna DeWitt Cosplay choker
Bioshock Infinite
Kion Cosplay
Bird..or Cage..?
Well, whatever you choose I can make you one!
BioShock Infinite Elizabeth cosplay brooch. I am taking commission for this jewelry.
- Brooch only or Brooch and choker
Interested? Simply write me here, on etsy or visit me on facebook via Kion Cosplay
Halloween Costume Contest
