Birch Bark Crown
1,986
16
Posted
Introduction: Birch Bark Crown
This simple crown can be woven from three strips of birch bark or paper.
Step 1: Materials and Tools
Birch Bark or Paper Strips
Knife or Scissors
Step 2: Lay Out
Line up two pieces of birch bark. Stagger the ends of the two pieces so that they will not join at the same spot.
Step 3: Add the Weft
Add the third, and longest piece, perpendicular to the first two. The perpendicular piece is the weaver or weft. Slide it under one piece and over the other.
Step 4: First Fold
Fold the weft under so that it runs parallel to the other strips.
Step 5: Second Fold
Fold the weft under itself again, so that the strip has turned 180 degrees.
Step 6: Weave the Weft
Weave the weft back under and through.
Step 7: Repeat
Repeat until  additional material needs to be added in. When the weft is too short to weave back through, trim 45 degrees off the end.
Step 8: Adding to the Weft
Trim the next piece of weft at 45 degrees and tuck it through the weave into the last fold and resume weaving.
Step 9: Join the Warp
Wrap the warp back around and weave it back trough the weft to create the head bands for the crown. The crown will be stronger if the joints are staggered.
Step 10: Finnish the Weave
Weave the warp the entire way around the crown. Join the two ends of the warp the same way that previous sections have been linked. I liked the pattern on my crown better when I flipped it inside out.
Step 11: Try It On
Check the fit, and wear it proudly.
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    2 Comments
    Sweet! That birch one looks just awesome :) It looks so easy and I'm glad you showed how to add to the weft, otherwise I would be confused on how to keep going with multiple pieces.
