Bird Cabin
Published
Introduction: Bird Cabin
I have been binge watching Longmire and I have been loving all the different log cabins. However, I noticed you do not see any log cabin birdhouses. Here is a bird cabin I built with notched beams. It resembles a log cabin. It is easy to cut the pieces and it is fun for most any age to assemble.
Step 1: Procure Lumber and Rough Cut
I purchased a 6ft, 1x10 common pine board in the cull pile at the local home improvement center. At 70% off, I got it for four dollars and it will be enough to make two cabins.
Start by cutting the board into four piece 13" long and one piece 17" long. This only uses 69" of the 72" length so you have extra stock to cut around knots. From the 13" long pieces, rip six pieces 1-3/8" wide. From the 17" long piece, rip one piece 6-1/4" wide and two pieces, 1-3/8" wide.
From the photo you can see the wood looks pretty sad.
Step 2: Mill Wood
Plane all of the pieces to a width of 11/16" and then plane the 6-1/4" wide board to a thickness of 1/2". Then cut the narrow pieces to 1-3/16" wide and the base piece to 6" wide.
Step 3: Cut to Length
For each cabin you will need; 1 base 8" long, 2 large gables 8" long, 2 small gables 4" long, 18 beams 6" long, and 4 connecters 1-3/4"long. For the stock prepared in the previous step, after cutting around knots, I was able to get: 2 bases, 5 large gables, 5 small gables, 37 beams, and 10 connectors. Plenty enough pieces for two cabin with some spares.
Step 4: Dado Notches
Cover the working service of your dado cutting cradle and tack into place a thin sheet of plywood or MDF. Install your 3/4" dado blade and make a cut into the cradle. The edge of the MDF will show the exact edge of where the dado starts. Set the height so the dado blade cuts 5/16" deep. The dimensions for cutting each of the piece types are given in the included PDF.
Step 5: Bevel Gables and Spilt a Beam
Each of the four gables need to be beveled and one of the beams needs to be split in half. I did this all with a scroll saw. Dimensions are given in the included PDF.
Step 6: Bevel Beams, Connector, and Gables
To make the pieces look more like logs. Tip the blade of your table saw to 45 degrees and rip an 1/8" off each edge.
Step 7: Cut Roof Slats
Take 1/4" lath and, for each cabin, cut eight slats 8" long. Then rip them to a width of 1-1/4".
Step 8: Dye the Pieces
You will want to dye the pieces. The dye I like to use is Fiebing alcohol based leather dye.
Dye
It comes in 4 oz bottles but I mix it with 28 oz of denatured alcohol to make a quart of alcohol based dye. It cost about $10. The dye come in 28 different colors. I used medium brown for the beams/connectors, green for the roof pieces and red for the gable pieces. I wish I had gotten dark red but all in all I am still happy.
I use an acid brush to apply the dye to the pieces. With so much alcohol it pretty much immediately penetrates and there is not need to wipe the piece after application.
Step 9: Assembly, Lay the Foundation
Start by measure 17/32" and 5-17/32" away from the back of the base. Then glue the two half beams into place. I use Rapid Fuse cynoarcrylic wood glue.
RadidFuse..
Best wood glue I have found on the market. It dries in 30 minutes. If you use an accelerator it takes 10 seconds.
Step 10: Assembly, Lay Bottom Layers
Stack and glue 10 beams, five layers high.
Step 11: Assembly, Top Layers
Stack and glue the four connectors and six beams to complete the top layers.
Step 12: Assembly, Gables and Crossbeam
Stack and glue the gable pieces and remaining beam.
Step 13: Assembly, Roof
Start be gluing one slat at the gable peak. Set the Slat 1" away from the back gables. This will give 1" overhang in the back and 2" in front. Continue gluing slats in place into the roof is completed.
Step 14: Variation
If you don not like the big 2-1/2" entry then replace
the four connectors with two beams. Clamp two beams together and drill the desired sized entry hole.
Final Note
As a salute to Henry in Longmire, I did not use any contractions in this Instructable!
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    4 Comments
    Hi. Nice design, but did you get actual birds settling ?
    I'm asking because as far as I know (which is not much) the entry hole size and shape is very important, and yours seems quite wide.
    I just built it and yes the hole is too large. It turns out that the hole size is determined by the type of birds you want to attract. That was why I included step 14 where you take two of the beams and drill the appropriate size hole for birds you have.
    Nice design. I like the wood block cabin idea and look. You do need to put something over the very peak to keep rain out though. And does the dye you use have any problems with the birds? IDK, I'm just asking.
    Thank you for the king words. I will work on covering the peak. I don;t think it will be a problem with the birds. It is alcohol and pigment. Once dry it is only pigment, There is no problems with horses and they are very touchy animals.
