Bird Cage Out of a Fan
4,656
6
4
Posted
Introduction: Bird Cage Out of a Fan
Hi guys! I'm going to show you how to turn a broken fan into a beautiful bird cage
Step 1: Fan
Take an old or broken fan and start taking it apart
Step 2: Scissor
Take a scissor and cut the cord of the fan
Step 3: Parts
Now these are the parts you're going to use of the fan
Step 4: Stainless Steel Wire Mesh
Get a stainless steel wire mesh with small holes 0.5 cm
Step 5: Measuring Tape
Bring a measuring tape and mark horizontally 1.30m and vertically 30cm
Step 6: Pliers
Take a pliers, remove the small parts on the fan grill and throw them away
Step 7: Cover
Take a plastic bucket cover, clean it and put it on the bottom grill
Step 8: Sewing
Now take the wire mesh and the bottom grill and start sewing them together using the fan cord
Step 9: Sewing
I bought two pieces so i'm gonna sew them together, you don't have to do this if you get 1.30m in length
Step 10: Scissor
Take the scissor and cut a square 16x16cm
Step 11: Door
Cut 20x20cm from the remain wire mesh to make a door
Step 12: Wire
Take a wire, cut it into 4 pieces, bend the pieces then use them to attach the door to the cage
Step 13:
Now take another wire, bend it's 2 sides and secure it on the door to use it to open and close the cage
Step 14: Sewing
Put the second grill on top of the cage and sew it with a cord exactly like you did to the bottom one
Step 15: Food Bowl
Take a bowl, make 2 close holes in the back using a scissor, take a wire and fix it in the bowl then attach the bowl inside the cage
Step 16: Water Dispenser
Now make a rectangular hole with the scissor and use a wire to secure the water dispenser
Step 17: The Swing
To make the swing take a long wire, bend it then take a paper and wrap it around the bottom part
Step 18: Tape
Take a wire tape and roll it around the paper
Step 19: Thin Cables
Take 2 thin cables, put them in the swing then attach the swing to the top grill of the cage
Step 20:
Make a perch with roling 2 wires together then rolling a cord around them
Step 21: Wood Perch
You can make a wood perch too by taking a small dry branch from a tree and putting it in the cage
Step 22: Newspaper
Put a newspaper at the bottom of the cage
Step 23: Food
Put food in the bowl
Step 24: Toys
Put toys in the cage
Step 25: Hanger
Take a bent wire and fix it on the top of the cage to make a hanger
Step 26:
Put the bird in the cage and that's it (^‿^).
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Trash to Treasure
      Trash to Treasure
    4 Comments
    The screen appears to be galvinized, which is deadly to birds. In addition to be far too small for any bird. Please do not do this.
    it's stainless steel not galvanized
    that cage size is only large enough for a canary at best and does nothing for its psychological health. captive birds need corners as a place to retreat to in times of stress. with the round cages being open on all "sides" without corners or a covering will lead to significantly increased stress and a shortened lifespan. I do hope if you plan on cage building for a bird do some real research into their particular needs as they are many and change with each species.
    i think that's a perfect cage for him plus i have a bird room and i let him fly out of the cage for some time, he is 5 years old now and he never had health problems or been stressed out.
