3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Biscornu (offset square cushion)
Biscornu is a French adjective that means "that which has an irregular form, with projections" or "complicated and bizarre."
To a seamstress or an embroiderer, a biscornu is a tiny eight-sided embroidered pillow that can be used as a pincushion, an holiday ornament, key chain/cell phone decoration, a scissor fob, the centerpiece of a wreath, filled with flower petals or herbs to make a sachet... They're great for anything that you can think to do with a tiny cushion. Biscornus can be cross-stitched, embroidered, hardangered (is that even a word?), anything as long as each side is square and the same size. I've even seen patchwork/quilted biscornus. Biscornus are very popular items for stitchers to exchange; there are many biscornu exchanges arranged online through blogs and forums.
Step 1A note about size
A note about size
Biscornus can be any size that you desire, only limited by your skill and the materials that you use (the smaller the biscornu, the more difficult it is to turn the corners). I've made biscornus ranging in size from 3/4 of an inch in diameter all the way up to nearly couch cushion size. Most biscornus fit comfortably in the palm of your hand and are made using two pieces of fabric about 4" or 5" wide each. I've chosen to use the slightly-larger-than-average Hallowe'en biscornu that I made for caerbannog for this tutorial because it's easier to see the details.
7 comments
Jan 7, 2011. 9:11 PMroverriffer says:
Where do you get your Halloween pattern? It is cute!
Sep 21, 2007. 1:01 PMjauncourt says:
These are gorgeous - and really easy, for the effect you get. I think it might be neat to make one in knitted squares, too.
Oct 17, 2007. 3:44 PMjauncourt says:
eep. I saw on your blog that you tried the knitted squares thing, and it was - meh (okay pillow, not so much on the nice biscornu shape). Now I can't find your blog to comment. So I'll comment here - It would probably work better if the knitted squares were either a really stiff kind of knitting, or were a blocked-to-square lace knitting sampler overlaid on a nice backing cloth, like satin or velvet. I'll try this and get back to you. Sorry for the incomplete thought :)
Oct 11, 2007. 9:06 AMCrazy Pillow says:
It is amazing how easy it is to do something, when it well explained. I want to try to make one as a key chain.
Elena
LenkArt, The Art of Decor
Oct 16, 2007. 8:25 AMCrazy Pillow says:
I will try to remember to do what you are suggesting. It probably will be more simplified in design.
Thanks,
Decorative pillows]http://www.lenkart.com
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:owntwohands
