Introduction: Biting Obstacles Autonomous Robot « Sanglier » (boar)
General concept
Our first idea was to create a tracked robot able to climb stairs and plenty of others obstacles, to reach a good speed (around 10 or 15 km/h) while filming and transmitting data. It will decide itself if it can go through an obstacle like a slope, stairs or a hole.  Recognizing people and following them, take panorama pictures, follow a GPS designate way are its objectives.
Step 1: Chassis
We made a wooden chassis because wood is cheap and easy to transform. We used 5 mm plywood. This chassis need to be quite big if you want to set batteries, engine and electronics in it and suspensions, wheels and turret at the exterior; there is no maximum size but making it too big can be a problem  for the gravity center of the robot when it climbs stairs.
Step 2: Tracks
This is one of the hardest parts of the construction so be prepared.
We used :
- 4 bicycles chains that a bike store gave to us (they are about 140/150 cm)
- 4 identical gearwheels that we bought near 5 € each
- wire
- aluminum rod (about 2.5 m)
- rubber (quite the same length than aluminum rod).
We attached the chains by pairs with the aluminum rod and wire and then we attached the rubber to them.
Power wheel are made of 2 gearwheels with one wooden disc between them. Be sure to have the same space between the chains at every new component you add, then you can circle your chains.
Here is our first test od the tracks !
Step 3: Turret
We used the same plywood for the chassis and the turret, you can do every design you want. The turret rotate with a Servo controlled by an Arduino, we replace the gun by a camera that can go up and down with another Servo. The roof plate is fixed by three screws so we can access easily to the inside, the other plates are pasted.
Step 4: Suspensions
We used 4 roller wheels, 4 RC car hydraulic suspensions (We will double them soon), and 1m of squared aluminum rod to make it more solid. We attached the rods and the suspensions together with screws. The wheels are link to the rods.
Step 5: Sensors
1) Obstacle detection :
To make an autonomous robot, we had to put a lot of sensors.
First, we had to determined what we had to detect, which obstacles.
- wall (impassable)
- stairs (passable)
- ditch/hole (impassable)
So we created a simulator which contain a few obstacles, and all the sensors we needed on the robot. (http://team-gs.fr/Robot%20Chenille/simulation.html)
Then, we had fix all of this sensors.
We are using ultrasonic sensors : HC-SRO4.
It's cheap and reliable.
2) Other sensors :
We added other sensors like 3-axis magnetometer (as compass), GPS module, 3 axis accelerometer and gyroscope.
These sensors are used to optimised the movements of the robot and allowed it to know where it is, and in which position.
All of these sensors were fix with plywood and 2mm screws.
Step 6: Assembling the Robot
This phase is relatively short. The turret is fixed to the Servo on the upper plate of the chassis, this place is also equipped with 2 fans, antennas, and 2 handles for an easy access to the inside of the chassis. The suspensions are screwed to the lateral plates (be careful of the tracks length). The tracks are posed on the power wheels; the motors are combined with a gear motor to generate more power.
Step 7: Programm
Actually, the programm is not operationnal.
The robot is Remote Controlled but not autonom.
But in a near future, we will try to implement the auto-detection of obstacle.
A video transmission of the raspi-cam to our netbook.
An automatic 360° panorama.
And finnaly, we will try to add some huge features like "people follow", "go back home", and why not face recognition ?!
Step 8: Conclusion
This robot is not finished but we are working on it !
We will post updates as soon as possible.
And some videos will come too !
UPDATE 2013/07/08 => 2 videos
Here is the video of the first move :
Battery Powered Contest
Remote Control Contest
Drones Contest
Drones Contest
