The solution, install a user replaceable fuse.
Radio Shack Parts:
270-0367 Panel-Mount Fuse-Holder $2.99
270-1021 Slow-Blow 1-amp fuses $2.99
18" of stranded wire, I used 12GA but 18ga would probably be acceptable
Tools:
Drill/ Dremel tool
Bits
Soldering Iron + Solder
#2 Phillips screwdriver
Remove these ads by
Signing UpStep 1Open the Unit
Remove the bottom piece of plastic.
Then remove the 4 screws on the side of the unit.
Remove the side, be careful not to loose the metal bar that holds the storage lid together.
I've included some pix. The first one is of the PCB and is a little clearer than your phone pix. The green arrow shows the offending fuse. The blue arrow shows where the AC wire from the switch is soldered to the PCB.
The second pix is the reverse side of the PCB. The blown fuse is already removed (green arrows) and the blue arrow shows the solder point for the wire from the switch - which I unsoldered and connected to the end of the fuse holder. The other terminal on the fuse holder was connected with an 18 Ga wire to the "bottom" fuse contact (as shown in this pix)
The last pix shows the final mod. Purple dotted wire from switch to end of fuse holder. Green dotted wire from fuse contact point to sider of fuse holder. The electrical connection terminated by the blown fuse is now complete and protected.
If and when I do the mods, I will attempt to take clearer pix, or maybe a vid. Your instructions and tips should make this a fun little project. Again, thank you.
I also think at the time, I made a calculation based of the DC sides fuse to decide 1amp would work.
Looking at dvlamis's comment, he put the holder on the opposite side of the unit. from where I did, and soldered to the bottom back side of the PCB to the fuse leads. might be a little bit neater that way.
I noted what dvlamis did and also the location he placed the fuse holder on the back plate. I am thinking of taking the wire (red) from the switch and detaching it from the PCB and soldering it directly to the fuse holder, and then solder the other lead from the fuse holder like dvlamis did. An even "neater" solution.
But hey, without your initiative, we wouldn't be refining this.
One tip for others: I thought I had left plenty of room on the outside of the fuse holder. I would have placed it a bit closer to the center of the unit had I realized how close I was to the outside of the unit once I put it all back together again. In other words, make sure you don't drill your half-inch hole any farther out than I did. If you do, your fuse holder may hit the side of the unit once you put it all together again. Too bad B&D engineers can't just design this right in the first place.
I'll be checking out instructables.com for other tips on other devices in the future.
Part of this was because it was my first instructable and I decided to make it mid project I missed some pictures for steps, but I guess that is part of the learning experience. Also, haha the DC side still worked but, yeah I can see plenty of people not happy with a car powered air pump and tossing them, who knows I might be able to get a whole $20 now, or a check from Black and Decker for being awesome and fixing their horrible design.
