Introduction: Black Iron Pipe Table
I've been searching for the right project to my brand new tools to work. After searching for what seems like months I finally came across this post.
I knew I could build it and I knew I wanted to make this my first Instructables post. I hope you find it helpful and inspires you to build your own Black Iron Pipe Table.
Step 1: Tools
You aren't going to need much to create this awesome table.
Here is exactly what I used.
Drill:Ryobi 18-Volt One+
Circular Saw:Ryobi 18-Volt One+
Step 2: Building Materials
I thought I would be smart and ask the guys at Home Depot to take a bigger piece of black iron and cut it down to the different specifications I needed. Unfortunately I was informed that they can't cut pipes below a certain length, Whether that's true or not who knows.
On the bright side, they do carry pre-cut and threaded pipe at all the various lengths you are going to need. They also carry all the fittings and the wood you are going to need too.
Here is a breakdown of everything I used to build my table.
Wood:
$36.88 (2 pieces) 2 in. x 12 in. x 12 ft. Better Douglas Fir Lumber cut in half. giving me four 6ft pieces
Pipe:
$18.60 (12 Total) 3/4 in. x 3 in. Black Steel Nipple
$15.48 (4 Total) 3/4 in. x 10 in. Black Steel Nipple
$23.64 (4 Total) 3/4 in. x 18 in. Black Steel Nipple
$15.58 (2 total) 3/4 in. x 24 in. Black Steel Nipple
Fittings:
$30.12 (12 Total) 3/4 in. Black Malleable Iron Threaded Floor Flange
$21.68 (8 Total) 3/4 in. Black Malleable Iron Threaded Tee
$ 8.28 (4 Total) 3/4 in. x 3/4 in. Black Malleable Iron 90-Degree Elbow
Total Cost of Materials: $170.26
Step 3: Layout and Fasten Your Boards Together
I used some old 1/2" wood we had in the garage
Step 4: Assemble the Pipe Legs
Screw the pipes together and attach the assembled legs to the upside-down table top. You might have to adjust the pipes for a bit to get a relatively level surface.
Step 5: Flip It and Sand It
Step 6: Congratulations You Have Yourself a New Table
This is where you can stain it and seal it, or use some Danish oil and seal it.
However you choose to finish your table is up to you. Which is part of the fun in building things like this.
