Well I wanted to take out the old batteries and install some Lithium-Ion batteries so they would be easy to replace in the future. I decided on a Li-Ion 3.6V 650mAh Rechargeable RCR123A battery. 2 of them in fact. Hooking them up in parallel will equal the original voltage. 3.6 is the original voltage. These batteries will not have the memory problem of the old batteries. You will need a new charger for them because the old one will over charge and you might have a fire. You'll also need 2 battery holders that are the right size for 123A batteries.
Tools you will need:
Dremel tool with cutting wheel
goggles
wire cutters
soldering iron
small flat head screwdriver
glue gun
120 grit sandpaper
Duco cement or equivalent
I think that about covers it.
Remove these ads by
Signing UpStep 1Taking the battery apart
It was suggested by easy-does-it to use boiling water to soften the plastic to remove. This idea should work better. Once the plastic starts to get soft I would think you could just pop it off.
Now that you have it off it is time to use the dremel to cut out the end so we can remove the batteries. Don't forget to use your goggles.
Try and cut as close to the edge as possible. There is a rubber washer on the inside at the end and will probably start to smoke once it heats up. You'll see it once you start cutting in deeper. Remove the rubber washer. Once that is done the batteries should fall out. Just tap it on the table and it should come out. The battery that comes out last will have a metal cup spot welded to the positive terminal. Use the screwdriver to pop it off. Don't bend it. We need it. If the screwdriver isn't working, use a putty knife or pocket knife.
Now you can start cutting out a large slot like you see in the picture. Make it wide enough so you can fit the battery holders. Make sure the battery holders are set in deep enough with a battery installed. You don't want the batteries to be sticking out. Be sure and sand all metal edges so you don't end up cutting yourself.
Batteryspace.com "
Do you have part numbers for them so I can order from them?
Very nice write up.
Here is the part numbers you requested at Batteryspace.com :
Part Number: RCR123A36 - battery
Part Number: CH-RCR123A36 - charger
Or you can get 4 batteries and a charger with this
Part Number: CH-RCR123A36C01
Hope that is what you need. You probably built it already buy now LOL
Secondly, I have used recovered laptop cells to rebuild these versapak units. The cells used in most laptops are very probably the 18650 units that were mentioned above. The versapaks that I have rebuild with discarded laptop cells have lasted two years (upto this point - we'll see how much longer). Cheers!
1. Remove the cap in hot water as easy-does-it recomended. worked great.
2. Cut off the end of the Versapak using a Dremel tool. The entire bad NiCd assembly can now be pulled out.
3. Remove the positive "cap" from the off battery.
4. Carefully remove the metal strips connecting the 3 NiCds you'll need two to be re-used.
5. Solder one of these metal strip to the cap (step3) and pushed back into the cavity of the battery pack case. This will be your positive terminal for the screw driver.
6. solder the other strip to the back of your salvaged 18650 Li_ion battery so that it sticks out about 1/4 inch or more.
7. At the cut off end of the Versapak case, make 4 marks with a marker, and using your Dremel cut two quarter sections of the metal from the cut end to the "groove" of the metal case. This is for the cap to go back in later where you can remove it for charging the Li_ion off the container.
8. Using a Dremel with a burr bit, trim off the raised groove in the inside of the plastic cap that was on the Versapak at two of the quarter positions. The idea is that so you can slip this into the Versapak case, twist a quarter turn and you're now locked.
9. Put the Li_Ion battery into the case, making sure the back/negative tab sticks out and touch the metal case inside the hole. Cut a slightly larger faom rubber to keep the battery snug from the back, and put the trimmed plastic cap back on. You now have a Li-Ion Versapak.
10. To recharge the battery, just untwist the back cover, and place your 18650 in a universal charger. I'll send you a picture later if you want.
I made it with your boiling water instruction, the cap went off very easily! :-)
But now I don't know how to get further.
This is my "status quo" (higher resolution under http://www.pix6.de/pics/4d041061c5a8e.jpg )
easy1: Sorry for delayed response but just received your post today.
The secret is to "cut" off the end of the metal Versapak battery cylinder (seen in your top photo). I was very careful with my first one but found that there is sufficient material that you don't have to treat this step as critical. The object is to remove just enough material from the end of the Versapak cylinder so that the old Ni-Cad cells contained inside can be slid out. I used a Dremel parting-disk, but an electric grinder (used with reasonable care) works just fine. With the cylinder opened in this manner, the old Ni-Cad cells (3 of them) easily slide out. They are wrapped in a cardboard tube. I remove the cardboard tube and re-insert it back into the metal cylinder.
I then obtain my new Li-ion replacement cell and "adjust" its diameter to snugly fit in the cardboard-lined Versapak cylinder by wrapping about three layers of black electrical tape around the new cell. I then remove the positive center button from the old cells and solder it to the positive terminal of the new cell. Next, to the negative end of the new cell, I solder about 1 inch of copper braid (I think that 18 or 20 gauge stranded copper wire would work as well). I then insert the new cell, positive end first, into the Versapak cylinder and solder the end of the copper braid to the inside surface of the Versapak cylinder.
Now to "re-close" the cylinder I obtain a neoprene rubber cork (I found them at the local ACE hardware) which have the exact diameter as the Versapak cylinder. I depress the cork into the cylinder until it makes positive contact with the Li-ion cell. This step insures that there is sufficient "spring" pressure to maintain electrical contact between the positive button of the Li-ion cell and the connection to the tool in which it is used. I then drop the original "rubber" Versapak cap into boiling water for about 30 sec, then fit it back onto the newly restored cell.
Hopes this helps. The next time I restore a Versapak battery, I will take some photos and post them.
Also FYI, a short time age a fellow wrote an article in SERVO magazine describing a circuit which converts an original Versapak charger into a "smart charger" for NiMh cells. I believe the kit is presently available on eBay. Since this "kit" is designed for NiMh cells, it is not suitable for Li-ion or Li-Po cells. Maybe I will author an Instructable illustrating how to modify a Versapak charger so that it can be used to safety "smart" charge Lithium-based cells.
By the way, if you shouldn't know (but I guess you know already) the online service area of 'Black&Decker' regarding details about the 'Versapak' products, where you can find some manuals, spare parts and repairing drawings of the most tools, is here: http://service.blackanddecker.de
Many thanks for the hint regarding the SERVO article that I've read completely, but in my opinion this loader-pimping is a very expensive method, moreover it's not able to load the Li-batteries, as you said.
A "neoprene rubber cork" is the same as a cork for wine, e.g. these ones, isn't it? http://www.fischer-lahr.de/images/product_images/info_images/Art590KUNST1000GEL83774A70BEB04EC6A255B0BE28512EC4.jpg
I've read the updated version of your comment. So that means you primarily had been talking about the replacement with a single lithium battery?
Lithium would be very nice, according to more power of the B&D tools (do they really become more "aggressive" with Li-batteries in comparison to NiCd/NiMh?).
In Germany I could get a new Li-loader for about 25$ and easily connect it to the inner contacts of the original B&D loader (just completely bypassing the existing electronic), it would lie beside of the B&D loader.
In a sense I would be interested in the 'vp110'-batteries (= Versapak Gold NiMh), but it's simply not possible to get them in Europe, and Amazon.com (cheapest deal) doesn't ship them to Germany.
But which ones would bring more power (not endurance)?
Actually I had one original and untouched VP100 battery only which was totally broke down -> I did the "youtube"-hint and connected plus/minus of the VP100 vice versa with the poles of a 9,6V battery for 8 seconds periodically, let it rest for 15 minutes and loaded it for 20 hours in the VP120-loader. Incredible, it's as powerful as a new one now.
In addition I bought a new "Xcell" 3,6V NiCd battery (china ware, but pretty solid) for about 10$ one weak ago.
So today I've tested all my recently purchased VP-tools (really a lot, all in used condition) and I'm very satisfied and absolutely surprised! Couldn't find better tools for light duty/rarely operation at this ridiculous price (ebay).
Great thing, convinced! :-)
But a "little" more power for the circular saw (VP600) and the leaf blower (VP4300) would be very nice, maybe with NiMh or Li?
Sounds as if you have a good understanding of the important factors in this subject. I don't know if I can add much more info.
That is an excellent idea to just connect the ouput of a "smart" NiCad charger, or a "smart Li-ion charger, or a "smart" NiMh charger to the terminals of a Versapk charger (bypassing the original Blac&Decker circuitry). This is an easy way to convert the original ?dumb? charger into a useful one that does a good job with the battery of your choice. If one were to modify the original charger to just connect the battery terminals to an electrical jack, then it could be used for any type of original or modified Versapak battery by just pluging in an appropriate charger.
My opinion on the performance of the Black&Decker tools when powered by different types of batteries is that you will not see much difference at all in the "aggressive" output. This sort of depends on the voltage output pf the battery. The three popular choices of NiMh, NiCad and Li all discharge at about 3.6V over most of their discharge cycle. Also, the three types have (within reason) the same capacities (about 1200 to 2200 mAh). (Of course, the higher capacities will run the tool for a longer period.) And the price is about the same for any of the three if you buy OEM cells to rebuild the Verapaks. NiCad cost about $2.00 USD for 4/5 sub-c 1200 mAh, so that is $6.00 for per rebuilt Versapak. The Li 18650 cells sell for about $8.00 USD for 1800 mAh to about $12.00 for 2400 mAh. And the NiMh sell for $4.00 per cell for 3600 mAh which equals about $12.00 to rebuild a Versapak.
In your case, if you are interested in the B&D Gold-Pack, the way to go might to be buy the high capacity NiMh cells. I think you would have about three times the electric capacity over the B&D version of the GoldPack, but see my comment above about performance (versus endurance).
Everyone who uses NiCad batteries as a staple should pay close attention to your "rejuvenation" comment. I been doing that techenique for 20+ years with great success. Over 90% of "dead" NiCad cells will show good response to the treatment, and most of those will perform "like-new" for a long time after.
And finally, I think that a wine cork would work just fine. The ones I used are traditionally shaped tapered ones usually used in laboratories to stopper flasks.
Recovering batteries from laptops can be a good idea provided you know how to safely charge them. If they are 18650 then you can pick up a charger for them.
