Blackberry 88xx Custom Color Trackball
This is my first Instructable. RIM (Research In Motion) or Blackberry, whatever you want to call it, found it unnecessary to include the option of having a colored trackball on the 88xx series of Devices.
I am here to show you how you can beat the system by creating a custom colored trackball for your RIM 88xx.
So sit back and relax, lets go!
Step 1Remove Trim Ring
Remove Trim Ring
This is by far the most difficult part of the whole thing. To get this trim ring off, at least in my case, it almost feels like your are going to break it. BUT!! take your time and it will pop off.
You will need to take your fingernail and get it under the trim ring right above the T and Y. Take it slow and it will pop out.
26 comments
Dec 26, 2009. 9:17 AMbassmonkey says:
wow, i tried it on my curve and it looks awesome!
Nov 16, 2008. 11:35 PMpodup365.com says:
Great job on this Instructable. The pictures show extreme detail and the written instructions told me exactly what I needed to know. Thanks! Now my BB sports a blue track ball, too.
Oct 30, 2008. 1:06 PMbumble22 says:
I have a Blackberry Pearl. Worked just OK for me when I only colored the LED, then I figured a way to make it a dramatic color change. Be advised though trying my little tidbit may be more permanent than just coloring the LED. Follow the instructable as above but before you reassemble...color the trackball housing plastic the color you want the trackball to show. Then reassemble as shown in the instructable. Coloring the LED only tinged it for me so I figured the housing is actually letting the light through and coloring that piece will add to the effect. I choose red because my phone is red and now it looks more like the result picture as shown in the instructable. Very effect and cool instructable, thank you! P.S. For the Pearl try prying the Trim Ring from the top as in where it meets the screen, thats the easiest way because there is no attachment point there.
Nov 6, 2008. 8:56 PMNick.XIII says:
umm, if you just used BlingBall you coulda activated the red, green and blue leds and used those, and for a solid color, just cover the white led with a small piece of electric tape.
Dec 28, 2008. 2:30 PMbluenightweasel says:
sbgstudios,
ummm....one thing...
he was replying to a comment about a guy who had a BLACKBERRY PEARL
Nov 11, 2008. 1:51 AMjplkeekif says:
Also not all the Pearls have the polychromatic LEDs, the 8130 (Verizon's Pearl) doesn't, so this is actually a quick easy and cheap way of taking care of that.
Dec 7, 2008. 1:04 PMBPHuntley says:
I just did this to my 8310 (single white LED.) Nice!
Oct 30, 2008. 6:22 AMbobnonn says:
So easy. Awesome idea!
Oct 29, 2008. 1:10 AMOrbb says:
I would put up a pic, but too lazy ATM lol. I noticed this while looking at other instructables about Wii remotes and stuff, and while reading, I kept looking over at my BlackBerry thinking, "..........................................................................Get over here." Works. LOL. I got kinda worried while trying to pop off the trim, because I wasn't quite sure if my BlackBerry was like yours, but sure enough, one side came up, and the others soon followed. I did mine blue also, and it works just fine.
Oct 26, 2008. 3:28 PMjunits15 says:
wouldn't it be better in the long run to remove the led and replace it with a diffrent one?
Oct 26, 2008. 3:56 PMberky93 says:
it would, but it would be much harder. I doubt that sharpie will be a problem, theres really nothing besides dust that will ever touch that diode anyway, so nothing will rub off the marker
Nov 13, 2008. 6:50 PMtitancore says:
diodes are created with pigmented enclosures. if you sharpie the outside, itll fade and dustoff with time because of the light :)
Oct 26, 2008. 11:17 AMLuminousObject says:
Cool. Now if my dad will let me try this with his.
Oct 26, 2008. 2:15 PMBeanGolem says:
just "borrow" it secretly, color the LED, then return it before he's even aware anything happened. Although I have noticed that most BB users are attached at the hip to theirs. literally.
Oct 26, 2008. 4:01 PMLuminousObject says:
Yeah, his is usually with him all the time. I've renamed it the CrackBerry.
Oct 26, 2008. 9:56 AMHuggyBear says:
There is a program called color pearl that controls the led's electronically. I use it on my blackberry pearl, but im not sure if it will work for yours. It gives you instant control as to what color the ball is, and how bright. Just search it on google
Oct 26, 2008. 12:09 PMHuggyBear says:
mmmm thought so
Oct 26, 2008. 10:47 AMjoejoerowley says:
It would be really cool to add an self cycling RGB LED in there. Nice instructable!
Oct 26, 2008. 9:17 AMmweston says:
Thats creative!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sbgstudios
